May 29, 2024 at 7:56 pm
JHL
Subscriber -
May 30, 2024 at 5:48 am
Devendra Badgujar
Forum ModeratorHello,Â
Let me check and get back to you.Â
DevendraÂ
May 30, 2024 at 8:54 am
JHL
SubscriberThanks so much!
July 10, 2024 at 1:51 pm
JHL
SubscriberHello Devendra,
Any update?
Thanks!
July 15, 2024 at 12:58 pm
Devendra Badgujar
There is no direct way to do this. First you will need to split the body in half with upper part and lower diverging section. Than copy faces and paste those. Once you have faces you can this option shown below to thicken the surfaces in the Pull Tool.
For lower part again similar steps needs to be used. Let me know if this helps.Â
DevendraÂ
Viewing 4 reply threads
- The topic ‘add wall thickness’ is closed to new replies.
1885
1404
1303
