February 8, 2024 at 10:20 am
Klaus Rappenecker
SubscriberHi all,
Is it possible to add a new substep with a new force at a restart point after a fully solved simulation?
I have completed a solution and now I want to add an additional force that I forgot in the first solution. I can add a new substep but when I add a new force the restart points are lost.
Thank you for your help
February 8, 2024 at 9:42 pm
Ankush Choudhary
Ansys EmployeeHi Kluas,
If you are using Version 2023, then you can achieve this by using the Restart Analysis Extension.
In the workbench, go to the ACT start page > Manage Extensions > Restart Analysis Extension.
Please also check out the below post related to this.
/forum/forums/topic/reusing-restarts-from-multi-step-analysis-in-new-analysis/
- The topic ‘Add new substep und new force after restartpoint’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
1461
1287
1124
