August 18, 2022 at 6:42 am
mehran
SubscriberI am not able to add mesh in FDTD, can someone please guide me how can I enable that option?Â
August 18, 2022 at 5:18 pm
Guilin Sun
Ansys EmployeeNot sure which mesh you are refering. If it is for override mesh, you can try
 addmesh;
or directly add it.
The background mesh is built-in with FDTD object.
If there is an issue, please restart your computer, or reinstall the newest version.
September 22, 2022 at 2:28 pm
joe.zhong
SubscriberI am having teh same problem. I am following the " Setting Up the Simulation in Ansys Lumerical FDTD — Lesson 2" vidoe. After adding the "FDTD" from the "simulation" tab, when I click on the "Suliation" tab and select the mesh, there was nothing happen. No mesh was added to the model. (Lumerical: Release: 2022 R2.2, Version 8.28.3171)
September 22, 2022 at 5:30 pm
Guilin Sun
Ansys EmployeeÂ
If you are a commercial user, please send us email with details of your computer information. Registration can be found here: https://optics.ansys.com/hc/en-us/articles/5609426062483-How-to-register-for-support-with-Lumerical
Currently in the GUI there is a bug to add the override mesh, which is going to be fixed soon.
November 2, 2022 at 9:21 pm
sagar
SubscriberI am also facing the same issues. I am trying to add Meh from the simulation option, but nothing is happening.Â
November 3, 2022 at 4:28 pm
Guilin Sun
Ansys EmployeeIt was a bug. You can use script in the prompt:
 addmesh;
it will add the override mesh and then you can edit it.
November 3, 2022 at 5:25 pm
sagar
SubscriberThank you
- The topic ‘Add mesh is disabled in FDTD’ is closed to new replies.
5694
1891
1419
