July 20, 2021 at 2:25 pm
LuisFig
SubscriberHello. I am trying to make a cosimulation between Twin Builder (Simplorer) and Fluent. Basically i add a Fluent Component that has 2 outputs to the Simplorer and now I am unable to connect this outputs to the terminals of a resistor (with a wire) and the following warning shows up:
Connection violation: A non conservative output (the Fluent output) cannot be connected to a conservative pin or net (the resistor terminals).
Does somebody know how can I connect this 2 elements? I've tried to search in the web but I couldn't find a solution.
Thank you a lot
July 26, 2021 at 2:40 pmKarthik Remella
AdministratorHello Could you please share a screenshot of how you are connecting these elements?
Karthik
July 26, 2021 at 3:37 pmLuisFig
SubscriberHello Karthik First of all thank you for your help.
At this point, in order to implement my co-simulation, in the Simplorer, the Fluent component has 1 input and 1 output terminals that are connected to the terminals of a resistor (by a wire).
I've already been able to connect the Fluent component terminals with the resistor through components called C2NC (conservative to Non-conservative), but I am not sure if this is right because when I analyze (run) the Simplorer, the following errors show up in the FLUENT:
This is the screenshot of how my elements are connected:
I would very much appreciate if somebody could help me. Thank you in advance.
Viewing 2 reply threads- The topic ‘Add Fluent Component in Twin Builder (Simplorer)’ is closed to new replies.
5734
