Electronics
Electronics
Adaptive passes did not converge based on specified criteria
    • kitzo2
    • icellb1
      Hi, nThere are no error messages but warnings of not converge. You can just increase the maximum number of adaptive pass in your analysis setup to solve this warning.nAlso, may I ask if this the same project to that posted in another question Trying to animate magnetic field simulation for wireless power transfer?nIf you right click on result --> solution data, click matrix tab. Can you see any value if you switch to R,L or inductive coupling coefficient? I'd also like to see a screenshot of this window if possible. n
    • kitzo2
      Hello again,nYes, it is the same project! I increased the # of adaptive passes and now I get no more errors. I am a little confused on why I am getting no inductance, core loss...etc. Below are the screenshots you asked for. Thanks again!nnn
    • icellb1
      Hi, nFrom your Message Manager the design variation offset='2.5mm' is probably not analyzed so that's why there is no result for it. Instead of right clicking parametrics-->analyze, try going to Simulation tab on the top tool bar, then click Analyze all. Check the result again after analysis finishes. nAlso, make sure to check save fields and mesh in parametrics (Video 2:57) this time before analyzing. n
    • kitzo2
      Hello again,nIt ran this time. Thank you! I will use the analyze all now. below are the screen captures you asked for. nn
Viewing 4 reply threads
  • The topic ‘Adaptive passes did not converge based on specified criteria’ is closed to new replies.
