Adaptive meshing in mechanical apdl
    • MaryMor
      I would like to implement adaptive meshing for a buckling analysis which leads to high local distortion.
      I have developed my input files in mechanical APDL. I run into element excessive distortion error. I have tried slowing my load steps as well as refining mesh. However, I still have this. I wanted to try adaptive meshing in ANSYS to help me pass the convergence error.
      I would like to implement adaptive meshing in mechanical APDL since my input file is already developed there. I have tried the following commands after defining my component:
      esel,s,cent,z,45,60
      cm,MidElem,elem
      cmsel,s,MidElem,element
      NLADAPTIVE,all,add,energy,mean,1
      However, I get the following error:
      "No boundary nodes were detected during the NLAD/rezoning process"
      I don't know where the error comes from.
      Also, I was wondering is there any difference with the nonlinear adaptive meshing in ANSYS workbench and ANSYS mechanical APDL?
      Thanks,
      Maryam
    • Sandeep Medikonda
      See the examples listed in the Nonlinear Adaptivity Analysis Guide:
      Link 1
      I don't know the complete details of your model but try using the name of the component you are defining instead of all in the NLAD command.
      There is no difference, Mechanical writes out the ds.dat file which should have the same NLADAPTIVE commands. Now, you are using a energy-based criteria and might want to use mesh/box based criterion.
    • MaryMor
      Thank you.
      I tried your comment by using the name of the component, but that didn't help.
      Tried energy and box method, both cases get the same error.
  • The topic ‘Adaptive meshing in mechanical apdl’ is closed to new replies.
