January 18, 2023 at 2:08 pm
Leon Allmannsdörfer
SubscriberHello,
I´m simulating a special sensor by using Maxwell. It´s a magnetostatic simulation.
A gearwheel is imported as a step-file. Using a sweep oparation, the wheel turns for a certain angular. A magnet is placed in front of the gearwheel and between gearwheel and magnet is a tiny ferromagnetic box. With the fieldcalculator the fields inside the box are detected. If the objects are placed too close to each other, the signal changes drastically and is no longer usable.
The mesh meanwhile changes every step of the sweep.
Is it possible, that the changing mesh is the source of the problem with the signal?
If it is, is there a way to use the same mesh for every step? If it is not, what could be the problem?
Thanks in advance
Leon
January 19, 2023 at 2:32 pm
NKC
Forum ModeratorHi Leon,
What are you measuring as a signal here?
What do you mean by "the signal changes drastically and is no longer usable"?
If you are talking about the B field in the box, it will increase if you bring it close to the magnet.
Please share some screenshots of your setup to interpret it correctly.Regards,
Navya
January 20, 2023 at 11:56 am
Leon Allmannsdörfer
SubscriberHi,
I´m using the field calculator to charge the magnetization of the box. Therefore I use the calculatet values of B, H and a constant. Following this, the angular between the calculated vector and a constant vector is charged. The cos() of this angular is the signal im measuring. An integration over the volume of the box, followed by a scaling is also needed.
Sometimes the calculation returns nan and sometimes the signal seems to be random, while it should be a cos()-function.
What could be the reason it returns nan?
In the latest attempts, i can see too high B-Vectors at the edges of the teeth of the gearwheel. I tried using a roung shape of the edges, but it only got worse.
Is there anything else i could try?
Leon
February 23, 2023 at 4:38 pm
DELI
Ansys Employeehi, field calculator is post processing which will not be able to excite the simulation.
February 23, 2023 at 3:27 pm
DELI
Ansys Employeehi, I would suggest adding more segments for the edge, and make mesh finer.
You can get the same mesh by linking mesh. First, create a source magnetostatics design and set the desired mesh in this design. Second, create target design, link the mesh in analysis setup (solver tab) and change max number of passes to 1(General tab).
- The topic ‘Adaptive mesh while using sweep operator’ is closed to new replies.
5934
1306
