TAGGED: adaptive-meshing, convergence, simulation-accuracy
March 16, 2023 at 8:42 pm
Miguel Sanchez
SubscriberHi,
I am trying to define an adaptive convergence process to refine the accuracy of the first results:
My model contains solid, surface and line bodies and I already learned that the last ones cannot be included so I setup the convergence object scoping only to solid and suface bodies:
However, the solve runs only the first loop so results remain the same as before:
I don´tknow why? Any ideas?
Thanks
March 24, 2023 at 8:36 am
Vinayak Vipradas
Ansys EmployeeHi Miguel,Â
Please refer to the following Ansys Help Document to check if you have followed all the steps to correctly define Adaptive Convergence and also the limitations of Adaptive Convergence:Â
Using Adaptive Convergence (ansys.com)Â
Regards,Â
Vinayak VipradasÂ
- The topic ‘Adaptive convergence for accuracy’ is closed to new replies.
5654
1890
1404
1303
