February 22, 2023 at 9:41 am
Waleed Ahmed
SubscriberHello,
I want to model a wind turbine using an actuator line model. Can you guide me on how it can be done in Ansys? I'm aware of actuator disk modelling, but for my master thesis, I need to use the actuator line model.
Thank you. -
February 22, 2023 at 2:26 pm
Forum ModeratorWhat's the difference between the two approaches?
February 22, 2023 at 2:59 pm
Waleed Ahmed
SubscriberIn actuator line model, we consider blades of a turbine as line and apply lift and drag as source terms on the points.
February 22, 2023 at 4:10 pm
Forum ModeratorOK, so rather than a disk you need some rows of cells. You'll need to look at source term UDFs, and then how to map the line onto the Fluent 2d/3d mesh.Â
February 22, 2023 at 4:18 pm
Waleed Ahmed
SubscriberYes, that's what's I need help with. How to do it?
February 22, 2023 at 4:28 pm
Forum ModeratorI'd start with the UDF Manual. There's a reason we include some models for you to use: if you need something else it may need to be added.Â
- The topic ‘Actuator Line Model for wind turbines’ is closed to new replies.
5824
