May 3, 2022 at 2:54 pm
atankasali
SubscriberI have installed SpaceClaim 2021 R1 and have the activation ID. However, I am not able to open SpaceClaim. When I open the app, I get an error saying that no valid license file found.
May 4, 2022 at 5:51 am
Devendra Badgujar
Forum ModeratorHi Abhilash Tankasali
Can you please check if the license mode is set as Subscription? You can check this by launching Discovery Licensing Mode Manager from Windows Start menu. If the license option is set to floating, please set it to Subscription and try again. Then it will take the subscription license.
Regards.
- The topic ‘Activate SpaceClaim license’ is closed to new replies.
- Add-in Error Excel
- Fileformats
- Discovery 2025r2 failed to initialize
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- racing royals
- New Computer
1495
1386
1209
