September 27, 2017 at 11:19 amadminAnsys Employee
In ANSYS Meshing, Named Selections can be used to select or filter a set of geometric entities, like edges or faces, by using a criterion like size, type, or location. Please follow these steps to create a worksheet driven Named Selection: 1.Select geometry (e.g. edge or surface) 2.Right-Click > Create Named Selection. 3.Activate "Apply geometry items of same:" and select one of the 5 types (Size, Type, Location x, Location y, Location z). Note: This selection can be changed later, so feel free to select any one of the available checkboxes. 4.Press OK. In the Tree, select the Named Selection and a Worksheet will appear. In the Worksheet, the desired criteria for automatic selection of other geometry entities can now be defined by choosing an Action, Criterion, Operator, and Value.
Activate Criterion Based Selection in ANSYS Meshing
- The topic ‘Activate Criterion Based Selection in ANSYS Meshing’ is closed to new replies.
- ICEM CFD – Hexa mesh of a tapered wing with sharp trailing edge
- No mesh information was found in the input mesh file error
- CONVERTING STL FILE IN TO SOLID
- Element type definition – Ansys Workbench
- Varying ply angle in ACP
- ANSYS ACP Modelling Issue
- the matrix T in the cyclic symmetric formula!!
- Assiging one parameter as thinkness of few shell objects
- The meshing algorithm cannot find matching topology
- Connecting External Mesh and Beam Model in Ansys Workbench
1416
599
591
565
366
