August 28, 2019 at 12:46 pm
Mike3000
What is the best way to assign items to a named selection in ACT?
I know how to browse through items (parts, bodies, etc.) in the structure tree. But it seems to me that it is not possible to assign an item, for example a body directly to a named selection. An intermediate step seems to be to gather items in a selection and then assign the contents of the selection to a named selection.
However, I do not manage to add the items to a selection programmatically. The methods NewSelection as well as AddSelection need an input argument of type ISelectionInfo but I do not know how to obtain this from the Items I am browsing.
Below is an example where I have tried to assign each part to a named selection.
#Model
model = ExtAPI.DataModel.Project.Model
# Get parts
Parts = model.Geometry.GetChildren(DataModelObjectCategory.Part,True)
# The procedure will be included in a loop later. Just using first part in test.
MyPart = Parts[0]
# Selection
SlMn = ExtAPI.SelectionManager
SlMn.ClearSelection()
>>> Missing part: Adding "MyPart" to current selection <<<
# SlMn.NewSelection()
# Create named selection
NSn = model.NamedSelections
MyNS = NSn.AddNamedSelection()
MyNS.Name = "Part0"
MyNS.Location = SlMn.CurrentSelection -
September 3, 2019 at 10:46 am
Mike3000
SubscriberMeanwhile, I created a solution myself. It creates named selections for every part and assigns the part name to the corresponding named selection.
# Selection
Sel = SlMn.CreateSelectionInfo(SelectionTypeEnum.GeometryEntities)
#Model
# Get parts
print("Listing properties of Items:")
with Transaction(): Â Â Â Â Â Â Â Â Â # Suppress GUI update until finish to improve speed
   for Part in Parts:
      PName = Part.Name
      # print("Part name: ",PName)
      tmp_ls = []
      for Body in Part.Children:
         BName = Body.Name
         BId = Body.GetGeoBody().Id
         #print("Body name: "+BName+" ,BId: "+str(Id))
         tmp_ls.append(BId)                           # Collect all body Ids in temporary list
      # ExtAPI.SelectionManager.NewSelection(Sel)
      Sel.Ids = tmp_ls
      print("Sel.Ids: ",Sel.Ids)
      # Sel.Entities = [Body.GetGeoBody()]
      MyNS.Name = Part.Name
      MyNS.Location = Sel-
September 27, 2023 at 3:55 pm
a_l_o
SubscriberHi Mike,
Thank you so much for your script! It helped me a lot, cheers to you for posting it.
Greets! a-l-o
September 3, 2019 at 2:25 pm
Forum ModeratorThanks for posting the solution: we're very limited in how much coding support we're allowed to provide so always useful when users (and the wider community) can post answers.Â
September 28, 2023 at 7:40 am
erik.kostson
Ansys EmployeeThank you - closing this post.
Erik
- The topic ‘ACT Script: Assign items to a named selection’ is closed to new replies.
