July 16, 2021 at 12:33 pm
Ace
SubscriberHi All,
I am trying to use the "moving heat flux" plug-in to simulate the movement of the heat source. Through repeated attempts, I found that the "end time" parameter must be greater than 10 microseconds. Can this plug-in simulate a heat source for 100 nanoseconds or less? Does anyone know about this?
Thanks,
Ace
July 23, 2021 at 11:44 amAniket Chavan
Forum ModeratorHi Ace The extensions on the Ansys App store, come as is, with no support as per the clickwrap agreement that you agree to while downloading it. This could be due to functional limitations that this limit has been forced in the app. Fortunately, you can take a look at the source code that is included with the app to check the reason or to modify it to suit your needs!
-Aniket
Viewing 1 reply thread- The topic ‘ACT-Moving heat flux plug-in parameter setting problem’ is closed to new replies.
5024
1714
1387
1248
