January 24, 2024 at 11:32 am
lorenzo.orsini
SubscriberHi
I need to transfer the solid composite data from the setup of ACP (pre) to static structural in Ansys Workbench 2023 R2. Due to the nature of the geometry, I cannot use shell elements.The problem: When I start Ansys mechanical by clicking on the model tab, mechanical opens but gets stuck at 30% when importing the mesh. When I import the shell data, this does not happen and mechanical opens normally with the plies imported.
Can you give me some guidance on what my problem could be?
January 24, 2024 at 11:34 am
January 24, 2024 at 2:47 pm
Govindan Nagappan
Ansys EmployeeYou cannot switch between solid and shell composite model after you have connected the ACP-Pre Set up with Static structural Model
Can you delete the static structural and create a new one. Try to send the solid composite and see if it works. If it doesnt work, can you post the error messages
January 30, 2024 at 1:40 pm
lorenzo.orsini
SubscriberWhen I remove the Static structural analysis, and import the solid mesh into a new Static structural model, the problem persists. Because the meshing gets stuck at 30%, I shut it down with the task manager. I then get the following warning message in the workbench:
System.InvalidOperationException: Conversion Failed. Mesh import failed
  at Ansys.Addins.Infrastructure.Remoting.RemotingApiHelper.FatalApiMethodInvalidOperationException[TReturn](String message, RemotingApiMethod1 callback)2 modelConversionFilesMap, Dictionary
at Ansys.Simulation.Core.Commands.AddinModelAssembler.Convert(IFullContext context, MeshFileOptions meshFileOptions, IMeshToGeometryOptionsProvider meshToGeometryOptionsProvider)
--- Ans.ModelConverter.RemoteLib.Exceptions.ModelTransferFailedException: Conversion Failed. Mesh import failed
at Ans.ModelConverter.RemoteLib.AddinWorkflow.AssemblyBase.Assemble(IFullContext context)
at Ansys.Simulation.Core.Commands.AddinModelAssembler.Assemble(IFullContext context)
at Ansys.Simulation.Core.Commands.RefreshModel.ProcessAssemblyFiles(IFullContext context, Dictionary2 modelAssemblyFilesMap)1 componentsToRefresh, Boolean refreshUnfulfilled)
at Ansys.Simulation.Core.Commands.RefreshModel.ExecuteCommand(IFullContext context)
at Ansys.Addins.Infrastructure.CommandUtilities.CommandHelper.Execute(IFullContext context)
at Ansys.Core.Commands.Concurrency.CommandWorkUnit.executeInContext(CommandContext subContext, IExecutionEngineCallback tracer)
at Ansys.Core.Commands.Concurrency.BaseWorkUnit.doExecute(IExecutionEngineCallback executionEngine, CommandContext subContext)
at Ansys.Core.Commands.Concurrency.BaseWorkUnit.Execute(IExecutionEngineCallback executionEngine, Boolean dontCatchExceptions)
--- Ansys.Core.Commands.CommandFailedException: Conversion Failed. Mesh import failed
CommandName: Mechanical.RefreshModel(Container="Model 1", RemainingContainers=[])
at Ansys.Core.Commands.CommandAsyncResult.RethrowFailureException(Exception e)
at Ansys.Core.Commands.CommandAsyncResult.Wait(Int32 milliSecondsTimeout, Boolean exitContext)
at Ansys.ProjectSchematic.Commands.RefreshCommand.RefreshComponents(IFullContext context, IEnumerable
CommandName: RefreshComponent(Component="/Schematic/Component:Model 1")
  at Ansys.ProjectSchematic.Commands.RefreshComponentCommand.InvokeAndWait(IProtectedContext context, DataReference Component)
  at Ansys.Simulation.GUI.EditModelBase.InvokeEditModelOperation(GuiOperationContext context, IGuiOperation guiOperation, DataContainerReference dcr)
  at Ansys.UI.GuiOperationContext.Invoke(GuiOperationMetaData operationData)
  at Ansys.UI.UIManager.InvokeOperationCore(String pseudoname, OperationDelegate callback, Boolean allowOSMessages, Boolean coreTransaction, Boolean deferredRefreshOnly)
February 7, 2024 at 7:21 am
- The topic ‘ACP pre to static structural solid composite transfer not working’ is closed to new replies.
5819
