ACP Pre does not open in workbench
    • maname
      I cannot open ACP pre with workbench, and I received the error message like this
      Spawning process C:Program FilesANSYS Incv192ACPACP.exe exceeded timeout
      I can oopen ACP pre with standalone but not with workbench.
      How can I fix this?
      Thanks in advance!
    • cagdasakalin
      I am getting the same message when I try to initialize the ACP pre and I could not figure it out.
      Were you able to resolve the issue?
      I would appreciate it if you share any information related to this topic.
      Thanks
    • ANSYS_MMadore
      Could you please exit all ANSYS applications and try renaming your %APPDATA%Ansysv19x directory to v19x.OLD and see if that has any impact?
      Thank you,
      Matt
    • bco3883
      Is this solution just for a Windows machine? Do you have any recommendations for Linux?
    • ANSYS_MMadore
      On Linux this would correlate to $HOME/.ansys/v19x, so you would rename to $HOME/.ansys/v19x.OLD.
      Thanks
      Matt
    • gknsmt
      Hi Matt
      I also have same problem with Maname. ACP pre dosen't work and give me same error "C:Program FilesANSYS Incv181ACPACP.exe exceeded timeout".
      I tried your solution, but it couldn't work.
      Could you help me please?
      Thanks
    • HelenSE
      Hi maname, cagdasakalin and gknsmt,
      were you able to solve the problem?
      I ran into the same error and can't seem to fix it.
      Thanks and best regards, Helen
Viewing 6 reply threads
  • The topic ‘ACP Pre does not open in workbench’ is closed to new replies.
