October 28, 2018 at 10:26 pm
October 29, 2018 at 5:43 pm
April Wang
Ansys EmployeeHi Loui,
After define a solution by plywise in ACP-post, you can click on each ply under "modeling ply" from the tree outline to view solution on each ply.Â
April
October 29, 2018 at 7:31 pm
Loui
SubscriberHi April,
I do define plywise stress, but it remains greyed out for Scene.1. The stresses in "modeling ply" (plies) remain all the same (they should be different), when I click the plies in the tree. And none of the scenes have any properties to define. The "Scene.1" shows only "global" stresses, the user defined scenes (2 and 3) show nothing (both stresses are greyed out).Â
April 13, 2019 at 10:01 am
cagdasakalin
SubscriberHi,
I have the same problem that Loui posted above.
I implemented what it suggested for the solution but I could not achieve it.
After defining the solution in terms of displacement and clicking on the corresponding ply on the "ModelingPly" tree, ACP-post does not show up any color change on the geometry(please see the picture attached.). However, it does pop up the color bar on the left side of the result window.
I am kindly requesting your help.
Ça?da?
February 17, 2020 at 1:47 am
Despoinak
SubscriberHello everyone,Â
I have the same problem, did you have a solution for it or anything to suggest?
I am appreciate if you answer!
Best regards
Despina K.
June 28, 2020 at 1:52 pm
WillRobert
SubscriberHello,
I have this problem as well !
Will
April 30, 2021 at 6:14 am
ColinBeatty
SubscriberHello,
Has this problem been solved? I am currently running into this issue in ANSYS 2020R2
Colin
April 12, 2022 at 2:15 am
SaFaaH
Subscriber.Have u find the solution?
- The topic ‘ACP Post Scene Properties missing in tree’ is closed to new replies.
4673
1565
1386
1231
