November 11, 2024 at 3:23 pm
lyna.hechiche
SubscriberHi,I am currently using the ACP pre to do some FEM on a composite laminate. Im able to initialize the 3 first steps (Engineering Data, Geometry and Model) and to update them, but Setup does not want to update. I get the following error message with association A5: ''Échec de la mise à jour du composant Setup dans ACP (Pre). At least one exception occurred during the refresh that made it impossible for ACP to complete the process.''I work with the Workbench 2022. I also get an error while trying to save the work ''Object reference not set to an instance of an object''. Can you help me solve this problem?ÂThank you -
November 15, 2024 at 3:25 pm
bmercier
SubscriberÂ
Hi Lyna,Â
You can try to switch workbench in English not in French. I think it could help.Â
Regards,Â
BenjaminÂ
