January 24, 2024 at 4:26 pm
January 30, 2024 at 4:49 pm
Reno Genest
Ansys EmployeeHello,
Could you show a screensho of your stackup by clicking on the General tab in the Stackup Properties window? Do you have a stackup defined?
If you have a stackup defined, you should see the polar plot in the Analysis tab.
Reno.
February 8, 2024 at 2:54 pm
Maki Gen
SubscriberSorry for late reply,
The same situation occurred when I checked the Material Data defined already in ACP. Interestingly, the constitutive matrix can be calculated and the entire simulation process is not affected.
Once, It noticed me in Python view that "UnicodeDecodeError: 'utf-8' codec can't decode byte 0x82 in position 0: invalid start byte". And I suspect that the software is incompatible due to an operating system update to Win11.
Still dealing with this and sincerely thank you for your reply.
April 9, 2024 at 3:37 am
MarimEmad.AbdRabou00
SubscriberI'm facing same problem. have you found a solution?
- The topic ‘ACP CLT polar showing problem’ is closed to new replies.
5824
UVLYV~AY63OET5J214S4.png)
