May 30, 2024 at 11:12 pm
castrohenrique0208
Subscriber -
May 31, 2024 at 9:17 am
ErKo
Ansys EmployeeÂ
Hi
Do not use the ACT extension.
Use the ANsys native acoustics systems called Harmonic Acoustics.
See here for a tutorial
https://www.youtube.com/watch?v=Kq3iuYK52gc
Also now when you have acoustic domain on one side only of the shell, that is OK - use shared topology so share nodes on the interface between the 2 domains and avoid using contacts between them (see tutorial where share topology is used) .
(As we said we can not have an acoustic domain on both sides of a shell/surface body, but on one side like shown in the image is OK)All the best
Erik
June 3, 2024 at 1:49 pm
castrohenrique0208
SubscriberHi Erik
I want to perform an modal simulation to extract the modes using only the panel, then the acoustic cavity and then the system panel+ acoustic cavity.
After I want to perform an harmonic analysis to extract the sound pressure level generated in the system panel + acoustic cavity.
I don't know if the video that you sent apply for this case, because I am using the acoustic body below the panel (surface not a solid), as you can see in the image.Â
My main goal is to extract the sound level pressure, but I'm a little bit ansure about the process.Â
I try to do as you said using the harmonic acoustic, but i'm still get it the same ? error when trying to apply the FSI.Â
I'm sending the link of the project, if you can see it would be great.Â
https://drive.google.com/file/d/1Z4rF8_8GrcDAtkhSrxcktSqV-H69sgCE/view?usp=drive_link
June 4, 2024 at 6:39 am
ErKo
Ansys EmployeeHi
It is because you are still using the ACT extension.
Do not use the extension and it is fine as you found out since you posted another post where it all works ok.
Erik
PS: Ansys Empl. can not downlaod any files - perhaps some forum members can help
June 5, 2024 at 2:12 pm
castrohenrique0208
SubscriberHello Erik,Â
Can you explain me why I can't use the ACT extension for this case?Â
Thanks in advance.Â
- The topic ‘ACOUSTIC – FLUID STRUCTURE INTERACTION’ is closed to new replies.
5804
