Electronics
Electronics
ACIS to Parasolid
    • d.maiboroda
      Hello everyone. I've run into an issue: I decided to take the courses on Learning Hub, but when I try to open the examples, this error occurs.
      The error message is: "'5SE_ViaWWDMPS3.aedt' was created with ACIS geometry kernel. It cannot be accessed by Electronics Desktop version 2025R1 and beyond. Please use 2024R2 version to translate into Parasolid."
    • zongbo.wei
      hi:
      This is because the geometry kernel was changed in the version after 25 version, so you can open these files with the 24 version and save them, and then use the versions after 25 to open the saved files.
    • d.maiboroda
      Thank you for the answer, but it is highly inconvenient to maintain multiple versions AEDT for a start. Secondly, these files are located on the Learning Hub, and the issue is that to learn something, one needs to have several AEDT versions. How can this be explained to customers?
