Achieve moment convergence for an impact problem in static analysis
    • pgl
      How to achieve moment convergence for an impact problem in static analysis?
    • cbhavsar
      1. Try reducing the angle between two parts before going for impact analysis - this helps in reducing the applied load. 2. Reduce the FKN value in the contact settings. 3. Use impact constraints for time step controls. 4. Increase the number of substeps.
  • The topic ‘Achieve moment convergence for an impact problem in static analysis’ is closed to new replies.
