October 25, 2021 at 1:21 am
SergioSuarez
SubscriberHello,
I am trying to use the LS-Dyna explicit solver on Ansys, but the product launcher gives the error in the image attached. Any help on how to bypass this issue would be greatly appreciated.
October 25, 2021 at 10:57 amAniket Chavan
Forum ModeratorAnsys staff can not download any files on the forum, so if you want to reach a larger audience to get answers from, please insert inline images describing your problem.
-Aniket
October 25, 2021 at 11:51 pmAndreas Koutras
Ansys EmployeeI tested the APDL Product Launcher in versions 2021R2 and 2020R2 and works for LS-DYNA. Can you upgrade to a newer versions? Alternatively, you can run LS-DYNA with LS-RUN. I see that it is included in the installation packages of 2021R2 and 2020R2. I hope this helps.
Viewing 2 reply threads- The topic ‘Accessing LS-Dyna Explicit Solver on Ansys’ is closed to new replies.
5934
1307
