October 15, 2024 at 11:31 am
rani.a
SubscriberHi,
I am doing a harmonic analysis for a product which has directly been derived from static structural.
I have applied the frequency (min and max) as a logarithimic pattern and acceleration as input with fixed points at the mounting location.Theoratically, I have acceleration range based on different frequency values.
Is there any method/way to add a particular acceleration value to a certain frequency value in the harmonic analysis? If not, what else can be done?Regards,
Rani -
October 15, 2024 at 11:44 am
ErKo
Ansys EmployeeHi
Under the acceleration magnitude instead of Constant use Tabular (Frequency).
All the best
Erik
October 15, 2024 at 12:47 pm
October 15, 2024 at 12:53 pm
rani.a
SubscriberAlso, to your notice, I have not added acceleration in the static structural. I do not want acceleration applied on static analysis as you can see in the above tree snapshot.
October 15, 2024 at 12:59 pm
ErKo
Ansys EmployeeÂ
Hi
Just click inside the X-Component 10000 mm/s2 and a black arrow will appear (see in the images show in the below post) on the right hand side of this box (10000 mm/s2) – click on that arrow and change from Constant to the other option we said.
(https://innovationspace.ansys.com/forum/forums/topic/incremental-force-in-static-structural/)
All the best
Erik
October 15, 2024 at 1:00 pm
October 15, 2024 at 1:07 pm
rani.a
SubscriberHi,
Thank you Erik & Mohan for the response, I shall try it after my solving is done.
Also, this is the values of acceleration that can be added w.r.t the frequency, right. But, I have a frequency range of 7Hz-18Hz with 10mm/s2, 18-25Hz with 10-20mm/s2 and 25-200Hz with 20mm/s2.
How can I give a value for a logarithimic sweep. Attached below is the snapshot of the analysis settings, I used.
Awaiting for a quick response.Regards,
Rani -
October 15, 2024 at 1:14 pm
rani.a
SubscriberAlso, my test requires a sweep from 7Hz to 200Hz and back to 7Hz in a log sweep in 15 mintues timeline.
I can get from 7Hz to 200Hz. But is there a way to do it back from 200Hz to 7Hz under a total timeline of 15 minutes?Regards,
Rani -
October 15, 2024 at 1:47 pm
rani.a
SubscriberÂ
A further doubt from the previous results I just recieved.
After solving, I have received a result that is not acceptable and I would like to know the reason/corrections needed.The body that is supposed to be moving inside due to vibration and is moving outside the enclosure during the vibration.
The body in red are supposed to be foam material to prevent deformation from vibration & shock, but they are also over-expanding/over-compression than the reality requirement.ÂHow can I restrict this vibration movement to within inside enclosure. Is it something to do with the contacts.
Also, the top brackets that are mounted on top of the blocks are mounted by bolts to the welded to the outer body are also moving outside the nut areas which are not supposed to.
Please help me with this issue as well to check on a smooth solution as per requirement.
October 15, 2024 at 2:02 pm
ErKo
Ansys EmployeeHi
We (Ansys empl.) can not provide much further help here to the follow up questions, as one would need to look at the model in detail - here I would suggest to submit a support request (e.g., to your channel partner - as this forum is not for providing detailed support to customers).
All the best
Erik
October 15, 2024 at 3:43 pm
rani.a
SubscriberHi,Â
thank you for the response. How can we  submit a support request?
October 16, 2024 at 6:45 am
ErKo
Ansys EmployeeHi
Please speak to the person in your company that handles Ansys licences (or an engineer that has created a support to the channel partner (CP)) - they should know which and how to contact the CP that provides support to you.
All the best
Erik
- The topic ‘Acceleration Range in Harmonic Analysis’ is closed to new replies.
5969
1307
