October 28, 2025 at 10:22 pm
parsaary
SubscriberHi,
I need some help for speeding up a 2-way coupled fluent-rocky simulation being run on an HPC. Currently using a single node since I think rocky doesn't work on multinode. The current allocation is 4 gpu's for rocky, 20 cpu's for fluent, and the remaining 4 cpu's in the node are left free to be used for data transfer between rocky and fluent. I don't know what the bottle neck is, but I have pasted below an exerpt from the fluent and rocky logs at the same flow time. Thanks for your help!
Fluent log:
...Signal received from Rocky....Reading Rocky data....Rocky data read message sent!Flow time = 0.0005170320000002374s, time step = 25060********************************************************************Elapsed time = 4099.916666666666 s********************************************************************Â/solve/dual-time-iterate 1 50Updating solution at time level N... done. iter continuity   u-water u-particle   v-water v-particle   w-water w-particle   k-water k-particle  eps-water eps-partic vf-particl   time/iter 30380 2.4872e-06 3.0265e-07 0.0000e+00 2.1331e-07 0.0000e+00 3.5284e-08 0.0000e+00 2.4211e-05 0.0000e+00 1.6416e-09 0.0000e+00 1.1737e-05 0:10:07  50Â...ReceiveFluentDataReadMessage Received...Exporting Fluent flow data to Rocky!...Exporting Reference Density = 1.23e+00...Fluent flow data written to Rocky!...Fluent data sent to Rocky! 30381 2.5017e-06 3.0370e-07 0.0000e+00 2.1372e-07 0.0000e+00 3.5308e-08 0.0000e+00 2.4211e-05 0.0000e+00 1.6415e-09 0.0000e+00 1.1737e-05 0:09:55  49!30381 solution is convergedÂ...Signal received from Rocky....Reading Rocky data....Rocky data read message sent!Flow time = 0.0005170492000002374s, time step = 25061********************************************************************Elapsed time = 4100.716666666667 sÂÂÂRocky Log:CFDCoupling: Send CFD dataRocky current time = 5.17032e-05 iteration: 24048 last output time: 1.72172e-05CFD flow time: 1.72e-08 iteration: 0Sending fluent messageSend Rocky Data Write Message.Waiting for fluent messageFluent write data message received.Sent Fluent Data Read Message.CFDCoupling: Received CFD data. Target DT = 1.72e-08CFDCoupling: Send CFD dataRocky current time = 5.17204e-05 iteration: 24056 last output time: 1.72172e-05CFD flow time: 1.72e-08 iteration: 0 -
October 28, 2025 at 10:34 pm
parsaary
SubscriberÂ
Full Rocky Log: (my original post above didn’t include some details)
message
message date="2025-10-23 17:09:04" up_time="11:19:36.149"CFDCoupling: Send CFD dataRocky current time = 5.17032e-05 iteration: 24048 last output time: 1.72172e-05CFD flow time: 1.72e-08 iteration: 0message
message date="2025-10-23 17:09:04" up_time="11:19:36.150"Sending fluent messagemessage
message date="2025-10-23 17:09:08" up_time="11:19:40.675"Send Rocky Data Write Message.message
message date="2025-10-23 17:09:08" up_time="11:19:40.729"Waiting for fluent messagemessage
message date="2025-10-23 17:09:16" up_time="11:19:48.482"Fluent write data message received.message
message date="2025-10-23 17:09:17" up_time="11:19:49.283"Sent Fluent Data Read Message.message
message date="2025-10-23 17:09:17" up_time="11:19:49.283"CFDCoupling: Received CFD data. Target DT = 1.72e-08message
message date="2025-10-23 17:09:17" up_time="11:19:49.535"CFDCoupling: Send CFD dataRocky current time = 5.17204e-05 iteration: 24056 last output time: 1.72172e-05CFD flow time: 1.72e-08 iteration: 0
- affinity not set
1487
1363
1194
