May 6, 2021 at 7:05 am
htoiyob
SubscriberI have been trying to simulate wireless power transfer application using Ansys Electronic Desktop. I designed the coil model and ran it successfully. Then I designed a circuit in simpoler to tune the model through capacitive coupling. For that I had to run both AC sweep and Parametric Capacitance sweep simultaneously. (Yes i could change the value of Capacitance each time, but that is not a good practice i assume).
I Selected optimetric setup and set Cr(The receiving end capacitance value) to a table of data. But as I run the simulation it only shows graph for the nominal value.
How can i resolve this issue to run the whole batch of capacitance in the AC sweep?
June 29, 2021 at 3:30 pmViewing 1 reply thread- The topic ‘AC Sweep along with Parametric Sweep for tuning Wireless power transfer circuit in Simpoler’ is closed to new replies.
3762
1333
1168
1090
1014
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
