Ansys Innovation Courses
Provide feedback or ask questions related to the Ansys Innovation Courses content.
About Windmill Fan Blade Modal Analysis simulation example in the Structural Dynamics course
    • Igor67
      Doing the Windmill Fan Blade Modal Analysis simulation example based on the How To Video I can't get all of the windmill blades displayed on the final stage of the simulation (Solution). The application displays only one blade of the windmill fan when I plot the modal shape for the lowest frequency and right-click Total Deformation to select Evaluate All Results. Could anyone please advise what I have missed in the simulation settings?
    • Sean Harvey
      ,If you select Solution, you will see cyclic solution display and under that the number of sectors. Can you try and setting to the number of desired sectors, then evaluate all results to check if you see more sectors? If you specify zero it will go back to program controlled and should display the full 360. Let us know if this helps. Thank you! Sean
    • Igor67
      Hi,That really worked. Thank you for your advice, it sorted out the issue
    • Sean Harvey
      Great to hear. Thank you for letting us know. Regards, Sean
  • The topic ‘About Windmill Fan Blade Modal Analysis simulation example in the Structural Dynamics course’ is closed to new replies.
