December 31, 2023 at 5:09 pm
Manoj Kumar Desu
SubscriberI have set all parameters in my ansys fluent battery module and the min voltage was set to 2.8V yet in the voltage graph the curve is reaching below the set voltage upto 0.5V can you please help me with it and I am also attaching the screenshots of the set parameters (Google drive link).parameter photos
January 5, 2024 at 7:19 am
Murari Iyengar
Ansys EmployeeWhich version of Fluent are you using? I recommend to switch to 23R2, the latest version if you are using an older one.Â
January 5, 2024 at 7:25 am
Manoj Kumar Desu
SubscriberThank you sir for helping me out but i am using the latest version 23R2 version of ansys,please help me with that error
January 5, 2024 at 7:43 am
Murari Iyengar
Ansys EmployeeCan you share some screenshots of your battery model dialogue box? Which model and sub-model are you using? Are you using external data for parameter identification? If so, what does the parameter graphs look like? As Ansys staff, we are not permitted to access any external links due to security reasons.Â
January 5, 2024 at 7:51 am
January 8, 2024 at 12:47 pm
Murari Iyengar
Ansys EmployeeThe issue you're experiencing might be related to the experimental discharge period being too short, resulting in insufficient data to fit the curves. This could be due to a unit problem or an insufficient number of experimental data points. To have a meaningful discharge curve, the time period should cover a good portion of the Depth of Discharge (DOD) range. A good rule of thumb is to cover at least 80% of the depth of discharge curve at each charge rate (C-rate). If the battery is assumed to discharge to DOD=0.2, for instance, the sample period for C-rate=0.1 should be 0.8*3600/0.1 seconds, and for C-rate=1, it should be 0.8*3600 seconds. Note that the unit of time in the tool is always in seconds, so all discharge data should obey this convention. What do your curves look like?
January 15, 2024 at 3:17 pm
Manoj Kumar Desu
Subscriber -
January 15, 2024 at 3:55 pm
Manoj Kumar Desu
Subscriber -
January 15, 2024 at 4:30 pm
- The topic ‘About Voltage curve in my battery simulation’ is closed to new replies.
5964
1307
