November 21, 2024 at 2:51 pm
xiangyl
Subscriberi am trying to use *tread command to get the table which contains the relationship between temperature and time, and then use it as the boundary conditions. i have done it in mechanical apdl. but i don't know which dictionary should i put the files TS44, there is always errors"*TREAD cannot open file ".
November 21, 2024 at 3:03 pm
ErKo
Ansys EmployeeÂ
Hi
See *TREAD in the help manual.Â
Search here for TREAD, and or the internet – a quick search result:
https://www.eng-tips.com/threads/tread-command-problem.443210/In the above, the file is located in the solver files dir. If in different folder, then add the whole folder path – say if file is in the D: drive use :::: *TREAD,mytable,’D:\mydisp’,csv,,to_skip
All the best
Erik
- The topic ‘About using apdl command in workbench’ is closed to new replies.
5649
1885
1404
1303
