流体
流体
about transient computation in cfx
    • hu xiaowei
      How to perform transient calculation of axial flow compressor acceleration using CFX
    • Yuanyuan Xiao
      Hi Xiaowei,
      Sorry for late. Due to AIS system maintenance in June, your question was automatically closed, and I was unable to respond at that time. I’ve only just now been granted permission to reopen and reply to your question. I apologize for the late response and appreciate your understanding.
      The answer for your question is as below:
      • The general workflow is:
      ‐ Set the Analysis Type to Transient
      ‐ Specify the transient time duration to solve and the time step size
      ‐ Set up physical models and boundary conditions as usual
      • Boundary conditions may change with time
      ‐ Prescribe initial conditions
      • Use physically realistic initial conditions, such as a steady solution
      ‐ Assign solver settings
      ‐ Configure transient results files, transient statistics, monitor points
      ‐ Run the solver
      There is tutorial called "Chapter 14: Flow in an Axial Turbine Stage"
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v242/en/cfx_tutr/i1342578.html
      Hope they are helpful to you. Thank you.
  • 您必须登录才能回复此主题。
