June 13, 2023 at 8:13 am
Chandra Sekhar Narra
SubscriberHi all,
Can anyone tell me, how to give time steps(initial,minimum and maximum steps) for a creep analysis of 1000hours in Ansys?
Thanks in advance!
Kind regards
Chandra
June 13, 2023 at 9:02 am
June 13, 2023 at 9:46 am
SubscriberHi Sampat,
Thank you very much for your response.
I understand it now. I tried what you suggested but there some problem with initial time step, minimum time step and maximum time step. Actually it is working for larger time step sizes and I would like to reduce it, then Iam getting the errors?
Could you please help me with this regard?
Kind regards
Chandra
June 13, 2023 at 9:54 am
I understand it now. I tried to implement as per your suggestion. I gave initial time step, minimum time step and maximum time steps as larger values and it is working. But as far as I all these time steps sizes should be smaller values, I tried to give smaller values and am getting errors. Here am attaching the error.
Kind regards
Chandra
June 13, 2023 at 10:38 am
Sampat Kumar
Ansys EmployeeÂ
Hi Chandra,Â
Will you please check the error in the solver file? . Please check the error in the solver output file and upload the screenshot too. Please upload a screenshot of the analysis setting where you have entered the time step. Please upload both the time steps that you have used for successful and unsuccessful simulations.
Regards,Â
SampatÂ
June 13, 2023 at 11:19 am
I checked there, I can see only warnings but not errors. Below am attaching the screenshot of it.
Also am attaching the screenshots of Analysis settings both successful and unsuccessful simulations.
Here I posted the solution information.
Solver Output
 ANSYS Mechanical                                Â
 |  W E L C O M E  T O  T H E  A N S Y S (R) P R O G R A M    |
 *                 ANSYS 14.5 LEGAL NOTICES                  *
 * Copyright 2012 SAS IP, Inc. All rights reserved.          *
 * Unauthorized use, distribution or duplication is           *
 * prohibited.                                                *
 * Ansys is a registered trademark of ANSYS, Inc. or its      *
 * subsidiaries in the United States or other countries.      *
 * See the ANSYS, Inc. online documentation or the ANSYS, Inc. *
 * documentation CD or online help for the complete Legal     *
 * Notice.                                                    *
 * THIS ANSYS SOFTWARE PRODUCT AND PROGRAM DOCUMENTATION      *
 * INCLUDE TRADE SECRETS AND CONFIDENTIAL AND PROPRIETARY     *
 * PRODUCTS OF ANSYS, INC., ITS SUBSIDIARIES, OR LICENSORS.   *
 * The software products and documentation are furnished by   *
 * ANSYS, Inc. or its subsidiaries under a software license   *
 * agreement that contains provisions concerning              *
 * non-disclosure, copying, length and nature of use,         *
 * compliance with exporting laws, warranties, disclaimers,   *
 * limitations of liability, and remedies, and other          *
 * provisions. The software products and documentation may be *
 * used, disclosed, transferred, or copied only in accordance *
 * with the terms and conditions of that software license     *
 * agreement.                                                 *
 * ANSYS, Inc. is a UL registered                             *
 * ISO 9001:2008 company.                                     *
 * This product is subject to U.S. laws governing export and  *
 * re-export.                                                 *
 * For U.S. Government users, except as specifically granted  *
 * by the ANSYS, Inc. software license agreement, the use,    *
 * duplication, or disclosure by the United States Government *
 * is subject to restrictions stated in the ANSYS, Inc.       *
 * software license agreement and FAR 12.212 (for non-DOD     *
 * licenses).                                                 *
         ***** ANSYS COMMAND LINE ARGUMENTS *****
 BATCH MODE REQUESTED (-b)   = NOLIST
 INPUT FILE COPY MODE (-c)   = COPY
    4 PARALLEL CPUS REQUESTED
 START-UP FILE MODE          = NOREAD
 STOP FILE MODE              = NOREAD
 00408972         VERSION=WINDOWS x64    RELEASE= 14.5    UP20120918
 CURRENT JOBNAME=file 10:36:58 JUN 13, 2023 CP=     3.297
 PARAMETER _DS_PROGRESS =    999.0000000  Â
 /INPUT FILE= ds.dat LINE=      0
 DO NOT WRITE ELEMENT RESULTS INTO DATABASE
 *GET _WALLSTRT FROM ACTI ITEM=TIME WALL VALUE= 10.6161111  Â
 TITLE=
 teststatic--Static Structural (C5)                                          Â
 SET PARAMETER DIMENSIONS ON _WB_PROJECTSCRATCH_DIR
 TYPE=STRI DIMENSIONS=     248       1       1
 PARAMETER _WB_PROJECTSCRATCH_DIR(1) = J:\Projekte\18\18-020_AIF_FOGI_FlexOfenbetrw\4_Simulation\FEM_mechanical\Chandra\Draft\REFTIMESTEP\ChandraREfe1\_ProjectScratch\Scr26D5\
 SET PARAMETER DIMENSIONS ON _WB_SOLVERFILES_DIR
 PARAMETER _WB_SOLVERFILES_DIR(1) = J:\Projekte\18\18-020_AIF_FOGI_FlexOfenbetrw\4_Simulation\FEM_mechanical\Chandra\Draft\REFTIMESTEP\ChandraREfe1\teststatic_files\dp0\SYS-3\MECH\
 SET PARAMETER DIMENSIONS ON _WB_USERFILES_DIR
 PARAMETER _WB_USERFILES_DIR(1) = J:\Projekte\18\18-020_AIF_FOGI_FlexOfenbetrw\4_Simulation\FEM_mechanical\Chandra\Draft\REFTIMESTEP\ChandraREfe1\teststatic_files\user_files\
 --- Data in consistent MKS units.
 MKS UNITS SPECIFIED FOR INTERNAL  Â
 LENGTH       (l) = METER (M)
 MASS         (M) = KILOGRAM (KG)
 TIME         (t) = SECOND (SEC)
 TEMPERATURE  (T) = CELSIUS (C)
 TOFFSET           = 273.0
 CHARGE       (Q) = COULOMB
 FORCE        (f) = NEWTON (N) (KG-M/SEC2)
 HEAT              = JOULE (N-M)
 PRESSURE          = PASCAL (NEWTON/M**2)
 ENERGY       (W) = JOULE (N-M)
 POWER        (P) = WATT (N-M/SEC)
 CURRENT      (i) = AMPERE (COULOMBS/SEC)
 CAPACITANCE  (C) = FARAD
 INDUCTANCE   (L) = HENRY
 MAGNETIC FLUX     = WEBER
 RESISTANCE   (R) = OHM
 ELECTRIC POTENTIAL = VOLT
 INPUT UNITS ARE ALSO SET TO MKS
1
 ***** ANSYS - ENGINEERING ANALYSIS SYSTEM RELEASE 14.5    *****
 ANSYS Mechanical                                Â
 00408972         VERSION=WINDOWS x64  10:36:58 JUN 13, 2023 CP=     3.391
         ***** ANSYS ANALYSIS DEFINITION (PREP7) *****
 *********** Nodes for the whole assembly ***********
 *********** Elements for Body 1 "Probe_Teil3" ***********
 *********** Send User Defined Coordinate System(s) ***********
 *********** Set Reference Temperature ***********
 *********** Send Materials ***********
  IMPLICIT CREEP OPTION is used, CREEP MODEL is 10
 *********** Fixed Supports ***********
 *********** Define Force Using Surface Effect Elements ***********
 *********** Define Body Force Temperature ***********
 ***** ROUTINE COMPLETED ***** CP =        6.156
 --- Number of total nodes = 70239
 --- Number of contact elements = 189
 --- Number of spring elements = 0
 --- Number of bearing elements = 0
 --- Number of solid elements = 41056
 --- Number of total elements = 41245
 *GET _WALLBSOL FROM ACTI ITEM=TIME WALL VALUE= 10.6166667  Â
 *************************   SOLUTION      ********************************
 ***** ANSYS SOLUTION ROUTINE *****
 PERFORM A STATIC ANALYSIS
 THIS WILL BE A NEW ANALYSIS
 LARGE DEFORMATION ANALYSIS
 NEW SOLUTION CONTROL OPTION IS ACTIVATED,
 THE FOLLOWING COMMANDS ARE RESET TO NEW DEFAULTS:
 AUTOTS, DELTIM, NSUB, CNVTOL, LNSRCH, PRED, NROPT,
 TINTP, CUTCONTROL, OPNCONTROL, MONITOR, NEQIT, SSTIF, KBC.
 CONTACT TIME PREDICTIONS ARE BASED ON ELEMENT KEYOPT(7) SPECIFIED
 USE SPARSE MATRIX DIRECT SOLVER
 CONTACT INFORMATION PRINTOUT LEVEL   1
 NLDIAG: Nonlinear diagnostics CONT option is set to ON.
        Writing frequency : each ITERATION.
 DEFINE RESTART CONTROL FOR LOADSTEP LAST
 AT FREQUENCY OF LAST AND NUMBER FOR OVERWRITE IS   0
 DELETE RESTART FILES OF ENDSTEP
 ******************* SOLVE FOR LS 1 ****************
 SELECT      FOR ITEM=TYPE COMPONENT=  Â
 IN RANGE      2 TO       2 STEP       1
     189 ELEMENTS (OF   41245 DEFINED) SELECTED BY ESEL COMMAND.
 SELECT     ALL NODES HAVING ANY ELEMENT IN ELEMENT SET.
     426 NODES (OF   70239 DEFINED) SELECTED FROM
     189 SELECTED ELEMENTS BY NSLE COMMAND.
 SPECIFIED SURFACE LOAD PRES FOR ALL SELECTED ELEMENTS LKEY = 1  KVAL = 1
     SET ACCORDING TO TABLE PARAMETER = _LOADVARI41X                  Â
 SPECIFIED SURFACE LOAD PRES FOR ALL SELECTED ELEMENTS LKEY = 2  KVAL = 1
     SET ACCORDING TO TABLE PARAMETER = _LOADVARI41Y                  Â
 SPECIFIED SURFACE LOAD PRES FOR ALL SELECTED ELEMENTS LKEY = 3  KVAL = 1
     SET ACCORDING TO TABLE PARAMETER = _LOADVARI41Z                  Â
 ALL SELECT  FOR ITEM=NODE COMPONENT=  Â
 IN RANGE      1 TO   70239 STEP       1
   70239 NODES (OF   70239 DEFINED) SELECTED BY NSEL COMMAND.
 ALL SELECT  FOR ITEM=ELEM COMPONENT=  Â
 IN RANGE      1 TO   41245 STEP       1
   41245 ELEMENTS (OF   41245 DEFINED) SELECTED BY ESEL COMMAND.
 PRINTOUT RESUMED BY /GOP
 SELECT     COMPONENT _CM43                         Â
   70239 NODES (OF   70239 DEFINED) SELECTED FROM
   41056 SELECTED ELEMENTS BY NSLE COMMAND.
 SPECIFIED BODY FORCE TEMP FOR ALL SELECTED NODES SET ACCORDING TO
 TABLE PARAMETER = _LOADVARI43                   Â
 USE AUTOMATIC TIME STEPPING THIS LOAD STEP
 USE INITIAL TIME STEP SIZE OF 1.000000    FOR ALL DEGREES OF FREEDOM
 FOR AUTOMATIC TIME STEPPING:
  USE 0.1000000    AS THE MINIMUM TIME STEP SIZE
  USE 1.000000    AS THE MAXIMUM TIME STEP SIZE
 TIME= 1.0000  Â
 ERASE THE CURRENT DATABASE OUTPUT CONTROL TABLE.
 WRITE ALL ITEMS TO THE DATABASE WITH A FREQUENCY OF NONE
  FOR ALL APPLICABLE ENTITIES
 WRITE NSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE RSOL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE STRS ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE EPEL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE EPPL ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE EPTH ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 WRITE EPCR ITEMS TO THE DATABASE WITH A FREQUENCY OF ALL
 NONLINEAR STABILIZATION CONTROL:
 KEY=OFF
 DO NOT INCLUDE STRAIN RATE EFFECT ON ANALYSIS FROM THIS LOAD STEP ONWARDS (VISCOPLASTICITY/CREEP ANALYSIS).
 *GET ANSINTER_ FROM ACTI ITEM=INT       VALUE= 0.00000000  Â
 *IF ANSINTER_                        ( =  0.00000    ) NEÂ
     0                                ( =  0.00000    ) THEN  Â
 *ENDIF
 ***** ANSYS SOLVE   COMMAND *****
 *** WARNING ***                        CP =      6.453  TIME= 10:37:00
 Element shape checking is currently inactive. Issue SHPP,ON or       Â
 SHPP,WARN to reactivate, if desired.                                  Â
 *** NOTE ***                           CP =      6.641  TIME= 10:37:00
 The model data was checked and warning messages were found.           Â
 Please review output or errors file (                                Â
 l\Chandra\Draft\REFTIMESTEP\ChandraREfe1\_ProjectScratch\Scr26D5\file.e
 err ) for these warning messages.                                     Â
 *** SELECTION OF ELEMENT TECHNOLOGIES FOR APPLICABLE ELEMENTS ***
     --- GIVE SUGGESTIONS AND RESET THE KEY OPTIONS ---
 ELEMENT TYPE   1 IS SOLID187. IT IS NOT ASSOCIATED WITH FULLY INCOMPRESSIBLE
 HYPERELASTIC MATERIALS. NO SUGGESTION IS AVAILABLE AND NO RESETTING IS NEEDED.
1
 ANSYS Mechanical                                Â
 00408972         VERSION=WINDOWS x64  10:37:00 JUN 13, 2023 CP=     6.703
                      S O L U T I O N  O P T I O N S
  PROBLEM DIMENSIONALITY. . . . . . . . . . . . .3-D                Â
  DEGREES OF FREEDOM. . . . . . UX  UY  UZÂ
  ANALYSIS TYPE . . . . . . . . . . . . . . . . .STATIC (STEADY-STATE)
  OFFSET TEMPERATURE FROM ABSOLUTE ZERO . . . . . 273.15  Â
  NONLINEAR GEOMETRIC EFFECTS . . . . . . . . . .ON
  EQUATION SOLVER OPTION. . . . . . . . . . . . .SPARSE           Â
  CREEP MATERIAL PROPERTIES INCLUDED. . . . . . .YES
  NEWTON-RAPHSON OPTION . . . . . . . . . . . . .PROGRAM CHOSEN Â
  GLOBALLY ASSEMBLED MATRIX . . . . . . . . . . .SYMMETRICÂ
 *** WARNING ***                        CP =      6.875  TIME= 10:37:01
 Material number 2 (used by element 41057 ) should normally have at    Â
 least one MP or one TB type command associated with it. Output of    Â
 energy by material may not be available.                              Â
 *** NOTE ***                           CP =      7.000  TIME= 10:37:01
 The step data was checked and warning messages were found.            Â
 This nonlinear analysis defaults to using the full Newton-Raphson     Â
 solution procedure. This can be modified using the NROPT command.    Â
 *** NOTE ***                           CP =      7.016  TIME= 10:37:01
 The conditions for direct assembly have been met. No .emat or .erot  Â
 files will be produced.                                               Â
                     L O A D  S T E P  O P T I O N S
  LOAD STEP NUMBER. . . . . . . . . . . . . . . .    1
  TIME AT END OF THE LOAD STEP. . . . . . . . . . 1.0000  Â
  AUTOMATIC TIME STEPPING . . . . . . . . . . . .   ON
     STARTING TIME STEP SIZE. . . . . . . . . . . 1.0000  Â
     MINIMUM TIME STEP SIZE . . . . . . . . . . . 0.10000  Â
     MAXIMUM TIME STEP SIZE . . . . . . . . . . . 1.0000  Â
  MAXIMUM NUMBER OF EQUILIBRIUM ITERATIONS. . . .   15
  STEP CHANGE BOUNDARY CONDITIONS . . . . . . . .   NO
  STRESS-STIFFENING . . . . . . . . . . . . . . .   ON
  TERMINATE ANALYSIS IF NOT CONVERGED . . . . . .YES (EXIT)Â
  CREEP CRITERION . . . . . . . . . . . . . . . . none
  CONVERGENCE CONTROLS. . . . . . . . . . . . . .USE DEFAULTS
  COPY INTEGRATION POINT VALUES TO NODE . . . . .YES, FOR ELEMENTS WITH
                                                 ACTIVE MAT. NONLINEARITIES
  PRINT OUTPUT CONTROLS . . . . . . . . . . . . .NO PRINTOUT
  DATABASE OUTPUT CONTROLS
     ITEM    FREQUENCY  COMPONENT
      ALL      NONE             Â
     NSOL       ALL             Â
     RSOL       ALL             Â
     STRS       ALL             Â
     EPEL       ALL             Â
     EPPL       ALL             Â
     EPTH       ALL             Â
     EPCR       ALL             Â
 SOLUTION MONITORING INFO IS WRITTEN TO FILE= file.mntr        Â
 MAXIMUM NUMBER OF EQUILIBRIUM ITERATIONS HAS BEEN MODIFIED            Â
 TO BE, NEQIT = 22, BY SOLUTION CONTROL LOGIC.                        Â
           **** CENTER OF MASS, MASS, AND MASS MOMENTS OF INERTIA ****
 CALCULATIONS ASSUME ELEMENT MASS AT ELEMENT CENTROID
 TOTAL MASS = 0.19112  Â
                          MOM. OF INERTIA        MOM. OF INERTIA
 CENTER OF MASS           ABOUT ORIGIN       ABOUT CENTER OF MASS
 XC = -0.10619         IXX =  0.3672E-04     IXX =  0.4264E-05
 YC = 0.11654E-01     IYY =  0.2852E-02     IYY =  0.6904E-03
 ZC = -0.58301E-02     IZZ =  0.2871E-02     IZZ =  0.6905E-03
                        IXY =  0.2365E-03     IXY =  0.1628E-08
                        IYZ =  0.1299E-04     IYZ = -0.3473E-10
                        IZX = -0.1183E-03     IZX = -0.9838E-10
 *** MASS SUMMARY BY ELEMENT TYPE ***
 TYPE     MASS
    1 0.191125  Â
 Range of element maximum matrix coefficients in global coordinates
 Maximum = 5.886034316E+09 at element 41035.                           Â
 Minimum = 65445040.8 at element 2557.                                 Â
  *** ELEMENT MATRIX FORMULATION TIMES
 TYPE   NUMBER  ENAME     TOTAL CP AVE CP
    1    41056 SOLID187    31.734  0.000773
    2      189 SURF154      0.234  0.001240
 Time at end of element matrix formulation CP = 20.859375.             Â
 ALL CURRENT ANSYS DATA WRITTEN TO FILE NAME= file.rdb
 FOR POSSIBLE RESUME FROM THIS POINT
    FORCE CONVERGENCE VALUE = 0.1614     CRITERION= 0.8234E-03
 SPARSE MATRIX DIRECT SOLVER.
 Number of equations =     210162,   Maximum wavefront =   291
 *** NOTE ***                           CP =     25.422  TIME= 10:37:12
 The initial memory allocation (-m) has been exceeded.                 Â
 Supplemental memory allocations are being used.                      Â
 Memory allocated for solver =              1142.858 MB
 Memory required for in-core =               989.487 MB
 Optimal memory required for out-of-core =    83.514 MB
 Minimum memory required for out-of-core =    43.605 MB
 *** NOTE ***                           CP =     25.641  TIME= 10:37:12
 The Sparse Matrix solver is currently running in the in-core memory   Â
 mode. This memory mode uses the most amount of memory in order to    Â
 avoid using the hard drive as much as possible, which most often      Â
 results in the fastest solution time. This mode is recommended if    Â
 enough physical memory is present to accommodate all of the solver    Â
 data.        Â
 curEqn= 75168 totEqn= 210162 Job CP sec=    37.891
     Factor Done= 50% Factor Wall sec=     2.806 rate=20008.4 Mflops
 curEqn= 210162 totEqn= 210162 Job CP sec=    50.562
     Factor Done= 100% Factor Wall sec=     5.968 rate=18639.3 Mflops
 Sparse solver maximum pivot= 5.885850936E+09 at node 15690 UY.        Â
 Sparse solver minimum pivot= 92391.3386 at node 9092 UZ.              Â
 Sparse solver minimum pivot in absolute value= 92391.3386 at node 9092Â
 UZ.        Â
    DISP CONVERGENCE VALUE  = 0.1490E-01 CRITERION= 0.4978E-05
   EQUIL ITER  1 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.9956E-04
    FORCE CONVERGENCE VALUE = 3.778     CRITERION= 0.8744E-01
    DISP CONVERGENCE VALUE  = 0.4000E-05 CRITERION= 0.4978E-05 <<< CONVERGED
   EQUIL ITER  2 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.2861E-07
    FORCE CONVERGENCE VALUE = 0.1547E-05 CRITERION= 0.8922E-01 <<< CONVERGED
   >>> SOLUTION CONVERGED AFTER EQUILIBRIUM ITERATION  2
  *** ELEMENT RESULT CALCULATION TIMES
    1    41056 SOLID187    26.359  0.000642
    2      189 SURF154      0.062  0.000331
  *** NODAL LOAD CALCULATION TIMES
    1    41056 SOLID187     0.641  0.000016
    2      189 SURF154      0.000  0.000000
 *** LOAD STEP    1  SUBSTEP    1 COMPLETED.   CUM ITER =     2
 *** TIME =  1.00000        TIME INC =  1.00000  Â
 *** ANSYS BINARY FILE STATISTICS
 BUFFER SIZE USED= 16384
     136.438 MB WRITTEN ON ELEMENT SAVED DATA FILE: file.esav
     107.188 MB WRITTEN ON ASSEMBLED MATRIX FILE: file.full
      51.125 MB WRITTEN ON RESULTS FILE: file.rst
 *************** Write FE CONNECTORS *********
 WRITE OUT CONSTRAINT EQUATIONS TO FILE= file.ce        Â
 *************** FINISHED SOLVE FOR LS 1 *************
 ******************* SOLVE FOR LS 2 ****************
  USE 1.000000    AS THE MINIMUM TIME STEP SIZE
  USE 10.00000    AS THE MAXIMUM TIME STEP SIZE
 TIME= 0.36000E+07
 KEY=OFF
 IMPLICIT CREEP RATIO CONTROL          =   1.000  Â
 *** WARNING ***                        CP =    108.016  TIME= 10:37:42
 *** NOTE ***                           CP =    108.203  TIME= 10:37:42
1
 ANSYS Mechanical                                Â
 00408972         VERSION=WINDOWS x64  10:37:45 JUN 13, 2023 CP=   112.500
  LOAD STEP NUMBER. . . . . . . . . . . . . . . .    2
  TIME AT END OF THE LOAD STEP. . . . . . . . . . 0.36000E+07
     MINIMUM TIME STEP SIZE . . . . . . . . . . . 1.0000  Â
     MAXIMUM TIME STEP SIZE . . . . . . . . . . . 10.000  Â
  CREEP CRITERION . . . . . . . . . . . . . . . . 1.0000  Â
      ALL      NONE             Â
     NSOL       ALL             Â
     RSOL       ALL             Â
     STRS       ALL             Â
     EPEL       ALL             Â
     EPPL       ALL             Â
     EPTH       ALL             Â
     EPCR       ALL             Â
    FORCE CONVERGENCE VALUE = 0.1547E-05 CRITERION= 0.8569E-01
    DISP CONVERGENCE VALUE  = 0.9295E-09 CRITERION= 0.4978E-05 <<< CONVERGED
   EQUIL ITER  1 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.7226E-11
    FORCE CONVERGENCE VALUE = 0.4362E-11 CRITERION= 0.8743E-01 <<< CONVERGED
   >>> SOLUTION CONVERGED AFTER EQUILIBRIUM ITERATION  1
 *** LOAD STEP    2  SUBSTEP    1 COMPLETED.   CUM ITER =     3
 *** TIME =  2.00000        TIME INC =  1.00000  Â
 *** CREEP RATIO = 0.2626E-14  CRITERION FOR CREEP RATIO CONTROL = 1.000  Â
 *** AUTO STEP TIME: NEXT TIME INC = 1.0000     UNCHANGED
   EQUIL ITER  1 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= 0.7226E-11
    FORCE CONVERGENCE VALUE = 0.4359E-11 CRITERION= 0.8743E-01 <<< CONVERGED
 *** LOAD STEP    2  SUBSTEP    2 COMPLETED.   CUM ITER =     4
 *** TIME =  3.00000        TIME INC =  1.00000  Â
 *** CREEP RATIO = 0.2634E-14  CRITERION FOR CREEP RATIO CONTROL = 1.000  Â
 *** AUTO TIME STEP: NEXT TIME INC = 1.5000     INCREASED (FACTOR = 1.5000)
    FORCE CONVERGENCE VALUE = 0.1554E-10 CRITERION= 0.8569E-01
    DISP CONVERGENCE VALUE  = 0.1240E-14 CRITERION= 0.4978E-05 <<< CONVERGED
   EQUIL ITER  1 COMPLETED. NEW TRIANG MATRIX. MAX DOF INC= -0.9581E-17Â
Thank you!
Kind regards
Chandra
June 14, 2023 at 4:44 pm
Sampat Kumar
Ansys EmployeeHi Chandra,Â
There might be a possibility that the minimum time steps that you provided are not enough to converge the problem, and the solver may require more iteration steps to converge the problem. We usually increase the sub-steps if the solution is not converging. If you are able to get the solution as per your expectations in the required time, then it's good to follow that.
Regards,Â
Sampat -
June 15, 2023 at 9:42 am
I understand it now.Thank you very much for clarification.
I will follow this.
Kind regards
Chandra
June 15, 2023 at 10:04 am
Sampat Kumar
you can also check that When you decrease the end time of the simulation, in that case, you can try to lower the minimum time step and increase the maximum time step in the simulation. This will not change your simulation result but the solver will get the required steps for iteration to converge the simulation.Â
Regards,Â
SampatÂ
June 15, 2023 at 10:19 am
I will check this and I think what you said is correct, I tried this before, lower initial and minimum time steps had worked for lesser step end time without any errors.
Thanks for much clarification.
Kind regards
Chandra
- The topic ‘About time steps’ is closed to new replies.
5954
1307
