September 20, 2023 at 2:31 pm
rji229
SubscriberHello,
There is an issue of the Ls-dyna SPH simulation. When I use the solver on my University HPC to do a SPH simulation, the d3plot cannot fully generated. The total set steps are about 102 d3plots for normal termination, while after generating about 80 d3plots, the solver got stuck and the task reported an error after running out of time. However, when I use the LS-Run on my Windows desktop, the job could end normally. The solver version on the HPC is R 10.1 and the local solver on my desktop is R 13.0. I’m not sure whether the solver version led to that issue.
The message file for the failed job:
 Date: 09/15/2023    Time: 15:40:54    ___________________________________________________   |                         |   |  Livermore  Software  Technology  Corporation  |   |                         |   |  7374 Las Positas Road              |   |  Livermore, CA 94551               |   |  Tel: (925) 449-2500  Fax: (925) 449-2507    |   |  www.lstc.com                  |   |_________________________________________________|   |                         |   |  LS-DYNA, A Program for Nonlinear Dynamic    |   |  Analysis of Structures in Three Dimensions   |   |  Version : smp s R10.1.0  Date: 01/12/2018   |   |  Revision: 123264      Time: 16:34:46    |   |                         |   |  Features enabled in this version:        |   |   Shared Memory Parallel            |   |   ANSYS Database format             |   |   ANSYS License (ANSYS192)           |   |                         |   |  Licensed to:                  |   |                         |   |  Platform  : Xeon64 System           |   |  OS Level  : Linux 2.6.18 uum          |   |  Compiler  : Intel Fortran Compiler 16.0 SSE2  |   |  Hostname  : cascade051             |   |  Precision  : Single precision (I4R4)      |   |  SVN Version: 123300               |   |                         |   |  Unauthorized use infringes LSTC copyrights   |   |_________________________________________________| Input file: Run.k                                     Â The native file format    : 32-bit small endian Memory size from command line:  1000000000 ********  notice  ********  notice  ********  notice  ******** *                               * * This is the LS-DYNA Finite Element code.          * *                               * * Neither LSTC nor the authors assume any responsibility for * * the validity, accuracy, or applicability of any results   * * obtained from this system. Users must verify their own   * * results.                          * *                               * * LSTC endeavors to make the LS-DYNA code as complete,    * * accurate and easy to use as possible.            * * Suggestions and comments are welcomed.  Please report any  * * errors encountered in either the documentation or results  * * immediately to LSTC through your site focus.        * *                               * * Copyright (C) 1990-2018                   * * by Livermore Software Technology Corp. (LSTC)        * * All rights reserved                     * *                               * ********  notice  ********  notice  ********  notice  ********ÂLSTC Environment Variables:ÂLSTC_LICENSE=ansys Beginning of keyword reader                  09/15/23 15:40:54 expanding  memory to  1000000000 d     600 beginning of keyword reader contracting memory to    21002 d     600  expanding  memory to    81130 d   2212719  expanding  memory to    111130 d   2212719  expanding  memory to    171130 d   2212719  expanding  memory to    191576 d   2212719  expanding  memory to    212264 d   2212719  expanding  memory to    233264 d   2212719  Open include file: SPH_Ball_15x15x15.k expanding  memory to    255440 d   2212719  Open include file: SPH_Plate_90x90x30.k expanding  memory to    277440 d   2212719  expanding  memory to    299040 d   2212719  expanding  memory to    320640 d   2212719  expanding  memory to    342240 d   2212719  expanding  memory to    363840 d   2212719  expanding  memory to    385440 d   2212719  expanding  memory to    407040 d   2212719  expanding  memory to    428640 d   2212719  expanding  memory to    450240 d   2212719  expanding  memory to    471840 d   2212719  expanding  memory to    493440 d   2212719  expanding  memory to    515040 d   2212719  expanding  memory to    536640 d   2212719  expanding  memory to    558240 d   2212719  expanding  memory to    579840 d   2212719  expanding  memory to    601440 d   2212719  expanding  memory to    623040 d   2212719  expanding  memory to    644640 d   2212719  expanding  memory to    666240 d   2212719  expanding  memory to    687840 d   2212719  expanding  memory to    709440 d   2212719  expanding  memory to    731040 d   2212719  expanding  memory to    752640 d   2212719  expanding  memory to    774240 d   2212719  expanding  memory to    795840 d   2212719  expanding  memory to    817440 d   2212719  expanding  memory to    839040 d   2212719  expanding  memory to    860640 d   2212719  expanding  memory to    882240 d   2212719  expanding  memory to    903840 d   2212719  expanding  memory to    925440 d   2212719  expanding  memory to    947040 d   2212719  expanding  memory to    968640 d   2212719  expanding  memory to    990240 d   2212719  expanding  memory to   1011840 d   2212719  expanding  memory to   1033440 d   2212719  expanding  memory to   1055040 d   2212719  expanding  memory to   1076640 d   2212719  expanding  memory to   1098240 d   2212719  expanding  memory to   1119840 d   2212719  expanding  memory to   1141440 d   2212719  expanding  memory to   1163040 d   2212719  expanding  memory to   1184640 d   2212719  expanding  memory to   1206240 d   2212719  expanding  memory to   1227840 d   2212719  expanding  memory to   1249440 d   2212719  expanding  memory to   1271040 d   2212719  expanding  memory to   1292640 d   2212719  expanding  memory to   1314240 d   2212719  expanding  memory to   1335840 d   2212719  expanding  memory to   1357440 d   2212719  expanding  memory to   1379040 d   2212719  expanding  memory to   1400640 d   2212719  expanding  memory to   1422240 d   2212719  expanding  memory to   1443840 d   2212719  expanding  memory to   1465440 d   2212719  expanding  memory to   1487040 d   2212719  expanding  memory to   1508640 d   2212719  expanding  memory to   1530240 d   2212719  expanding  memory to   1551840 d   2212719  expanding  memory to   1573440 d   2212719  expanding  memory to   1595040 d   2212719  expanding  memory to   1616640 d   2212719  expanding  memory to   1638240 d   2212719  expanding  memory to   1659840 d   2212719  expanding  memory to   1681440 d   2212719  expanding  memory to   1703040 d   2212719  Open include file: MatFile_Y5_PA.k expanding  memory to   1732040 d   2212719  expanding  memory to   1815114 d   2212719  expanding  memory to   1896712 d   2212719  expanding  memory to   1978310 d   2212719  expanding  memory to   2059908 d   2212719  expanding  memory to   2141506 d   2212719  expanding  memory to   2223104 d   2212719  expanding  memory to   2639248 d   2212719  expanding  memory to   2884040 d   2212719  expanding  memory to   3128832 d   2212719  expanding  memory to   5821534 d   2212719  expanding  memory to   6066326 d   2212719  expanding  memory to   6311118 d   2212719  expanding  memory to   6737848 d   2212725  expanding  memory to   7153992 d   2212725  Memory required to process keyword   :   7153992 contracting memory to      1 d   2212725 end of keyword reader LS-DYNA will perform a structural only analysis Y5_PA_HV                                Â             ls-dyna smp.123264 s      date 01/12/2018 expanding  memory to     2767 d     666 material, node and element data expanding  memory to     2845 d     668 mat add general damage 0 expanding  memory to     2865 d     668 material added airbag porosity leakage expanding  memory to     2871 d     668 material properties expanding  memory to     2968 d    246487 element data for composite material expanding  memory to     2982 d   8323567 gradient of damage data expanding  memory to     3057 d   8323569 user control for contact interfaces contracting memory to     3039 d   8323569 thermal expansion 0 expanding  memory to    247830 d   8323569 temp index array for node sorting contracting memory to     3039 d   8568364 for boundary cond. vectorization contracting memory to     3039 d   9057946 arbitrary element numbering input contracting memory to     3039 d   9057946 thick shell int. pt. strain expanding  memory to     3597 d   10281906 process element material data expanding  memory to     5598 d   10281904 load curve data contracting memory to     3604 d   10281904 user_define_loading_set expanding  memory to     3804 d   10281904 regularize time history data expanding  memory to     3808 d   10281904 *DEFINE_ELEMENT_DEATH contracting memory to     3808 d   10281904 rigidwall definitions expanding  memory to    248600 d   10281904 nodal constraint sets contracting memory to     3998 d   10281904 contact interfaces expanding  memory to    494580 d   10281904 implicit contact 1 contracting memory to     4998 d   10282008 contact segment data 1 expanding  memory to   1228953 d   10282008 contact segment data 3 contracting memory to     3998 d   14493971 contact definition expanding  memory to    983386 d   14493971 rigid body contracting memory to     4638 d   14493995 contact friction expanding  memory to     4669 d   14493995 joints expanding  memory to   35744235 d   14494595 SPH elements expanding  memory to   36233817 d   14494595 discrete element contracting memory to   36233817 d   14739710 accelerometers expanding  memory to   36233917 d   14739710 rigid bodies for disp. termination contracting memory to   36233917 d   15474083 transformation to move nodes expanding  memory to   36233919 d   14739761 mat add cohesive 0 contracting memory to   36233919 d   14739761 sensor_control for curve expanding  memory to   36233921 d   14739761 flexible body 2 contracting memory to   36233921 d   14739761 implicit joints S t o r a g e  a l l o c a t i o n  Memory required to begin solution    :    37M Additional dynamically allocated memory:    15M                  Total:    51M    1 t 0.0000E+00 dt 1.10E-12 flush i/o buffers       09/15/23 15:41:07    1 t 0.0000E+00 dt 1.10E-12 write d3plot file       09/15/23 15:41:07   96 t 9.4113E-08 dt 9.41E-09 write d3plot file       09/15/23 15:41:58   103 t 1.8341E-07 dt 1.83E-08 write d3plot file       09/15/23 15:42:01   108 t 2.9539E-07 dt 2.95E-08 write d3plot file       09/15/23 15:42:04   111 t 3.8597E-07 dt 3.01E-08 write d3plot file       09/15/23 15:42:06   114 t 4.8081E-07 dt 3.33E-08 write d3plot file       09/15/23 15:42:08   117 t 5.8049E-07 dt 3.26E-08 write d3plot file       09/15/23 15:42:09   120 t 6.7355E-07 dt 3.07E-08 write d3plot file       09/15/23 15:42:11   123 t 7.7186E-07 dt 3.20E-08 write d3plot file       09/15/23 15:42:13   126 t 8.6933E-07 dt 3.56E-08 write d3plot file       09/15/23 15:42:15   129 t 9.7590E-07 dt 3.48E-08 write d3plot file       09/15/23 15:42:17   132 t 1.0795E-06 dt 3.37E-08 write d3plot file       09/15/23 15:42:18   135 t 1.1817E-06 dt 3.54E-08 write d3plot file       09/15/23 15:42:20   138 t 1.2895E-06 dt 3.64E-08 write d3plot file       09/15/23 15:42:22   141 t 1.3997E-06 dt 3.62E-08 write d3plot file       09/15/23 15:42:24   143 t 1.4717E-06 dt 3.61E-08 write d3plot file       09/15/23 15:42:25   146 t 1.5796E-06 dt 3.49E-08 write d3plot file       09/15/23 15:42:27   149 t 1.6842E-06 dt 3.46E-08 write d3plot file       09/15/23 15:42:29   152 t 1.7902E-06 dt 3.61E-08 write d3plot file       09/15/23 15:42:31 *** Warning 40042 (SOL+42)   Part ID = 5000001 plasticity algorithm did not converge for MAT15   time = 1.8989E-06, ncycle = 154   155 t 1.8989E-06 dt 3.67E-08 write d3plot file       09/15/23 15:42:33 *** Warning 40042 (SOL+42)   Part ID = 5000001 plasticity algorithm did not converge for MAT15   time = 1.9356E-06, ncycle = 155   157 t 1.9725E-06 dt 3.76E-08 write d3plot file       09/15/23 15:42:34   160 t 2.0818E-06 dt 3.59E-08 write d3plot file       09/15/23 15:42:36   163 t 2.1906E-06 dt 3.85E-08 write d3plot file       09/15/23 15:42:38   165 t 2.2671E-06 dt 3.78E-08 write d3plot file       09/15/23 15:42:40   168 t 2.3827E-06 dt 3.76E-08 write d3plot file       09/15/23 15:42:41   171 t 2.4913E-06 dt 3.90E-08 write d3plot file       09/15/23 15:42:43   173 t 2.5694E-06 dt 3.79E-08 write d3plot file       09/15/23 15:42:45   176 t 2.6795E-06 dt 3.31E-08 write d3plot file       09/15/23 15:42:47   179 t 2.7811E-06 dt 3.62E-08 write d3plot file       09/15/23 15:42:49   182 t 2.8865E-06 dt 3.85E-08 write d3plot file       09/15/23 15:42:51   184 t 2.9654E-06 dt 3.91E-08 write d3plot file       09/15/23 15:42:52   187 t 3.0777E-06 dt 3.68E-08 write d3plot file       09/15/23 15:42:55   190 t 3.1960E-06 dt 4.16E-08 write d3plot file       09/15/23 15:42:57 *** Warning 40042 (SOL+42)   Part ID = 5000001 plasticity algorithm did not converge for MAT15   time = 3.2376E-06, ncycle = 190   192 t 3.2788E-06 dt 3.88E-08 write d3plot file       09/15/23 15:42:58   195 t 3.3979E-06 dt 3.85E-08 write d3plot file       09/15/23 15:43:00   197 t 3.4761E-06 dt 4.04E-08 write d3plot file       09/15/23 15:43:02   200 t 3.5958E-06 dt 4.16E-08 write d3plot file       09/15/23 15:43:04   202 t 3.6748E-06 dt 3.24E-08 write d3plot file       09/15/23 15:43:05   205 t 3.7821E-06 dt 4.01E-08 write d3plot file       09/15/23 15:43:08   208 t 3.8980E-06 dt 3.79E-08 write d3plot file       09/15/23 15:43:10   210 t 3.9736E-06 dt 3.74E-08 write d3plot file       09/15/23 15:43:11   213 t 4.0845E-06 dt 4.02E-08 write d3plot file       09/15/23 15:43:13   215 t 4.1662E-06 dt 4.12E-08 write d3plot file       09/15/23 15:43:15   218 t 4.2846E-06 dt 4.04E-08 write d3plot file       09/15/23 15:43:17   220 t 4.3617E-06 dt 3.91E-08 write d3plot file       09/15/23 15:43:18 *** Warning 40042 (SOL+42)   Part ID = 5000001 plasticity algorithm did not converge for MAT15   time = 4.4007E-06, ncycle = 220   223 t 4.4836E-06 dt 3.87E-08 write d3plot file       09/15/23 15:43:21   225 t 4.5636E-06 dt 4.20E-08 write d3plot file       09/15/23 15:43:22   228 t 4.6917E-06 dt 4.26E-08 write d3plot file       09/15/23 15:43:24   230 t 4.7746E-06 dt 4.05E-08 write d3plot file       09/15/23 15:43:26   233 t 4.8991E-06 dt 4.24E-08 write d3plot file       09/15/23 15:43:28   235 t 4.9825E-06 dt 3.99E-08 write d3plot file       09/15/23 15:43:29   237 t 5.0618E-06 dt 3.95E-08 write d3plot file       09/15/23 15:43:31   240 t 5.1818E-06 dt 4.02E-08 write d3plot file       09/15/23 15:43:33   242 t 5.2621E-06 dt 4.03E-08 write d3plot file       09/15/23 15:43:35   245 t 5.3836E-06 dt 4.04E-08 write d3plot file       09/15/23 15:43:37   247 t 5.4663E-06 dt 4.22E-08 write d3plot file       09/15/23 15:43:39   250 t 5.5928E-06 dt 4.26E-08 write d3plot file       09/15/23 15:43:41   252 t 5.6780E-06 dt 4.16E-08 write d3plot file       09/15/23 15:43:42   254 t 5.7615E-06 dt 4.08E-08 write d3plot file       09/15/23 15:43:44   257 t 5.8819E-06 dt 4.13E-08 write d3plot file       09/15/23 15:43:46   259 t 5.9664E-06 dt 4.18E-08 write d3plot file       09/15/23 15:43:48   262 t 6.0951E-06 dt 4.30E-08 write d3plot file       09/15/23 15:43:50   264 t 6.1808E-06 dt 4.08E-08 write d3plot file       09/15/23 15:43:52   266 t 6.2609E-06 dt 4.32E-08 write d3plot file       09/15/23 15:43:53   269 t 6.3886E-06 dt 4.23E-08 write d3plot file       09/15/23 15:43:56   271 t 6.4683E-06 dt 3.99E-08 write d3plot file       09/15/23 15:43:57   274 t 6.5920E-06 dt 4.11E-08 write d3plot file       09/15/23 15:43:59   276 t 6.6769E-06 dt 4.32E-08 write d3plot file       09/15/23 15:44:01   278 t 6.7617E-06 dt 4.21E-08 write d3plot file       09/15/23 15:44:02   281 t 6.8906E-06 dt 4.39E-08 write d3plot file       09/15/23 15:44:05   283 t 6.9769E-06 dt 4.41E-08 write d3plot file       09/15/23 15:44:06   285 t 7.0638E-06 dt 4.34E-08 write d3plot file       09/15/23 15:44:08   288 t 7.1906E-06 dt 4.37E-08 write d3plot file       09/15/23 15:44:10   290 t 7.2781E-06 dt 4.24E-08 write d3plot file       09/15/23 15:44:11   292 t 7.3642E-06 dt 4.12E-08 write d3plot file       09/15/23 15:44:13   295 t 7.4925E-06 dt 4.40E-08 write d3plot file       09/15/23 15:44:15   297 t 7.5784E-06 dt 4.34E-08 write d3plot file       09/15/23 15:44:17   299 t 7.6630E-06 dt 4.21E-08 write d3plot file       09/15/23 15:44:18   302 t 7.7922E-06 dt 4.34E-08 write d3plot file       09/15/23 15:44:20   304 t 7.8801E-06 dt 4.19E-08 write d3plot file       09/15/23 15:44:22   306 t 7.9652E-06 dt 4.42E-08 write d3plot file       09/15/23 15:44:23   309 t 8.0970E-06 dt 4.45E-08 write d3plot file       09/15/23 15:44:26   311 t 8.1842E-06 dt 4.52E-08 write d3plot file       09/15/23 15:44:27   313 t 8.2732E-06 dt 4.44E-08 write d3plot file       09/15/23 15:44:29   315 t 8.3618E-06 dt 4.39E-08 write d3plot file       09/15/23 15:44:30   318 t 8.4897E-06 dt 1.07E-08 write d3plot file       09/15/23 15:44:33 *** Warning 40042 (SOL+42)   Part ID = 5000001 plasticity algorithm did not converge for MAT15   time = 8.5089E-06, ncycle = 1061ÂThe message file for the successful job:Â
 *       ANSYS 2023 R1      LEGAL NOTICES       *
 * Copyright 1971-2023 ANSYS, Inc.  All rights reserved.    *
 * Unauthorized use, distribution or duplication is       *
 * prohibited.                         *
 * Ansys is a registered trademark of ANSYS, Inc. or its    *
 * subsidiaries in the United States or other countries.    *
 * See the ANSYS, Inc. online documentation or the ANSYS, Inc. *
 * documentation CD or online help for the complete Legal    *
 * Notice.                           *
 * THIS ANSYS SOFTWARE PRODUCT AND PROGRAM DOCUMENTATION    *
 * INCLUDE TRADE SECRETS AND CONFIDENTIAL AND PROPRIETARY    *
 * PRODUCTS OF ANSYS, INC., ITS SUBSIDIARIES, OR LICENSORS.   *
 * The software products and documentation are furnished by   *
 * ANSYS, Inc. or its subsidiaries under a software license   *
 * agreement that contains provisions concerning        *
 * non-disclosure, copying, length and nature of use,      *
 * compliance with exporting laws, warranties, disclaimers,   *
 * limitations of liability, and remedies, and other      *
 * provisions.  The software products and documentation may be *
 * used, disclosed, transferred, or copied only in accordance  *
 * with the terms and conditions of that software license    *
 * agreement.                          *
 * ANSYS, Inc. is a UL registered                *
 * ISO 9001:2015 company.                    *
 * This product is subject to U.S. laws governing export and  *
 * re-export.                          *
 * For U.S. Government users, except as specifically granted  *
 * by the ANSYS, Inc. software license agreement, the use,   *
 * duplication, or disclosure by the United States Government  *
 * is subject to restrictions stated in the ANSYS, Inc.     *
 * software license agreement and FAR 12.212 (for non-DOD    *
 * licenses).                          *
 ***************************************************************   Date: 09/19/2023    Time: 15:42:25 Â
   ___________________________________________________Â
   |  Date   : 11/15/2022   Time: 13:48:14      |
   |  Version : smp s R13                |
   |  Revision: R13.1.1-13-g5480eca294         |
   |   FFTW (multi-dimensional FFTW Library)      |
   |   Interactive Graphics              |
   |   ANSYSLIC enabled                |
   |   MADYMO indirect coupling (7.2 or higher)    |
   |  Licensed to:                   |
   |  Issued by  : ANSYS                |
   |  Platform  : WINDOWS X64 (SSE2)          |
   |  OS Level  : Windows 8/10 & Srv 2016/2019 uam   |
   |  Compiler  : Intel Fortran XE 2019 MSVC++ 2019  |
   |  Hostname  : ENGR6321               |
   |  Unauthorized use infringes Ansys Inc. copyrights |
   |___________________________________________________|
 Command line options: i=C:\Users\rji229\Documents\fem_sph_circular\Test\1\Run.kÂ
            ncpu=1Â
            memory=97m Input file: C:\Users\rji229\Documents\fem_sph_circular\Test\1\Run.k             Â
 Memory size from command line:   97000000
 allocating  memory to   97000000 d     544 Initial allocation ********  notice  ********  notice  ********  notice  ********
 * Neither LST nor the authors assume any responsibility for  *
 * results.                          *
 * LST endeavors to make the LS-DYNA code as complete,     *
 * immediately to LST through your site focus.         *
 * Copyright (C) 1990-2022                   *
 * by Ansys, Inc.                       *
 ********  notice  ********  notice  ********  notice  ******** Beginning of keyword reader                  09/19/23 15:42:25
 expanding  memory to    20720 d     600 Â
 expanding  memory to    66080 d   2212719 Â
 expanding  memory to    98580 d   2212719 Â
 expanding  memory to   1578326 d   2272719 Â
 expanding  memory to   1606836 d   2272719 Â
 expanding  memory to   1629036 d   2280719 Â
 expanding  memory to   1744036 d   2280719                                 09/19/23 15:42:25
 Open include file: SPH_Ball_15x15x15.k                                09/19/23 15:42:25
 Open include file: SPH_Plate_90x90x30.k                                09/19/23 15:42:25
 expanding  memory to   1765932 d   2280719 Â
 expanding  memory to   2012200 d   5465002 Â
 expanding  memory to   2256992 d   5465002  Memory required to process keyword   :   2256992 Â
 Additional dynamic memory required   :   8647293  contracting memory to      1 d   5465008 end of keyword reader
 LS-DYNA will perform a structural only analysisÂ
 Y5_PA_HV                                Â
          ls-dyna smp s R13 R13.1.1_13_5480ec date 11/15/2022
 expanding  memory to     2001 d     1445 material, node and element data
 expanding  memory to     2071 d     1475 material properties
 expanding  memory to     2085 d   8324474 gradient of damage data
 expanding  memory to     2107 d   8324529 user control for contact interfaces
 contracting memory to     2087 d   8324531 thermal expansion 0
 expanding  memory to     2089 d   8324533 cross-sectional force definitions 0
 expanding  memory to    246880 d   8324547 temp index array for node sorting
 contracting memory to     2089 d   8569342 just because?
 expanding  memory to     4091 d   10283422 load curve data
 contracting memory to     2097 d   10283422 user_define_loading_set
 expanding  memory to     2297 d   10283422 regularize time history data
 contracting memory to     2101 d   10283422 *DEFINE_ELEMENT_DEATH
 expanding  memory to    492683 d   10528238 implicit contact 1
 contracting memory to     3101 d   10528344 contact segment data 1
 expanding  memory to   1227056 d   10528344 contact segment data 3
 contracting memory to     2101 d   14740307 contact definition
 expanding  memory to     2105 d   14740978 contact friction
 expanding  memory to   1715702 d   37752065 SPH elements
 expanding  memory to   1715802 d   38241723 rigid bodies for disp. termination
 expanding  memory to   1715872 d   38241723 save d3plot control data S t o r a g e  a l l o c a t i o n  Â
 Memory required to begin solution    :   2257K
 Additional dynamically allocated memory:    41M
                  Total:    43M
    1 t 0.0000E+00 dt 1.10E-12 flush i/o buffers       09/19/23 15:42:33
    1 t 0.0000E+00 dt 1.10E-12 write d3plot file       09/19/23 15:42:33
   96 t 9.4113E-08 dt 9.41E-09 write d3plot file       09/19/23 15:43:22
   103 t 1.8341E-07 dt 1.83E-08 write d3plot file       09/19/23 15:43:25
   108 t 2.9539E-07 dt 2.95E-08 write d3plot file       09/19/23 15:43:28
   time = 3.9317E-07, ncycle = 110
   111 t 3.9317E-07 dt 3.66E-08 write d3plot file       09/19/23 15:43:30
   113 t 4.6671E-07 dt 3.96E-08 write d3plot file       09/19/23 15:43:31
   116 t 5.9188E-07 dt 3.95E-08 write d3plot file       09/19/23 15:43:33
   time = 6.3133E-07, ncycle = 116
   118 t 6.7157E-07 dt 4.11E-08 write d3plot file       09/19/23 15:43:34
   121 t 7.9410E-07 dt 4.17E-08 write d3plot file       09/19/23 15:43:37
   123 t 8.8038E-07 dt 4.54E-08 write d3plot file       09/19/23 15:43:38
   time = 9.2573E-07, ncycle = 123
   125 t 9.6982E-07 dt 4.65E-08 write d3plot file       09/19/23 15:43:40
   127 t 1.0610E-06 dt 4.36E-08 write d3plot file       09/19/23 15:43:42
   130 t 1.1918E-06 dt 4.53E-08 write d3plot file       09/19/23 15:43:44
   132 t 1.2849E-06 dt 4.77E-08 write d3plot file       09/19/23 15:43:46
   134 t 1.3799E-06 dt 4.74E-08 write d3plot file       09/19/23 15:43:48
   136 t 1.4746E-06 dt 4.63E-08 write d3plot file       09/19/23 15:43:50
   138 t 1.5663E-06 dt 4.43E-08 write d3plot file       09/19/23 15:43:51
   time = 1.6532E-06, ncycle = 139
   140 t 1.6532E-06 dt 4.69E-08 write d3plot file       09/19/23 15:43:53
   143 t 1.7969E-06 dt 4.83E-08 write d3plot file       09/19/23 15:43:56
   145 t 1.8806E-06 dt 3.90E-08 write d3plot file       09/19/23 15:43:57
   147 t 1.9626E-06 dt 4.46E-08 write d3plot file       09/19/23 15:43:59
   150 t 2.0788E-06 dt 3.60E-08 write d3plot file       09/19/23 15:44:02
   153 t 2.1979E-06 dt 4.44E-08 write d3plot file       09/19/23 15:44:05
   155 t 2.2817E-06 dt 3.75E-08 write d3plot file       09/19/23 15:44:06
   158 t 2.3922E-06 dt 3.80E-08 write d3plot file       09/19/23 15:44:09
   160 t 2.4720E-06 dt 4.60E-08 write d3plot file       09/19/23 15:44:11
   time = 2.5625E-06, ncycle = 161
   162 t 2.5625E-06 dt 3.95E-08 write d3plot file       09/19/23 15:44:13
   time = 2.6020E-06, ncycle = 162
   time = 2.6867E-06, ncycle = 164
   165 t 2.6867E-06 dt 4.71E-08 write d3plot file       09/19/23 15:44:15
   167 t 2.7825E-06 dt 4.80E-08 write d3plot file       09/19/23 15:44:17
   time = 2.8306E-06, ncycle = 167
   169 t 2.8726E-06 dt 3.94E-08 write d3plot file       09/19/23 15:44:19
   171 t 2.9541E-06 dt 4.63E-08 write d3plot file       09/19/23 15:44:21
   174 t 3.0939E-06 dt 4.62E-08 write d3plot file       09/19/23 15:44:24
   176 t 3.1808E-06 dt 4.38E-08 write d3plot file       09/19/23 15:44:26
   178 t 3.2728E-06 dt 4.89E-08 write d3plot file       09/19/23 15:44:28
   180 t 3.3658E-06 dt 4.24E-08 write d3plot file       09/19/23 15:44:30
   183 t 3.4967E-06 dt 4.81E-08 write d3plot file       09/19/23 15:44:33
   time = 3.5926E-06, ncycle = 184
   185 t 3.5926E-06 dt 4.22E-08 write d3plot file       09/19/23 15:44:35
   187 t 3.6749E-06 dt 4.20E-08 write d3plot file       09/19/23 15:44:37
   189 t 3.7631E-06 dt 4.85E-08 write d3plot file       09/19/23 15:44:39
   time = 3.8117E-06, ncycle = 189
   191 t 3.8592E-06 dt 4.25E-08 write d3plot file       09/19/23 15:44:41
   194 t 3.9923E-06 dt 4.82E-08 write d3plot file       09/19/23 15:44:43
   196 t 4.0878E-06 dt 4.72E-08 write d3plot file       09/19/23 15:44:45
   198 t 4.1826E-06 dt 4.38E-08 write d3plot file       09/19/23 15:44:47
   200 t 4.2747E-06 dt 4.86E-08 write d3plot file       09/19/23 15:44:49
   202 t 4.3722E-06 dt 4.90E-08 write d3plot file       09/19/23 15:44:51
   204 t 4.4688E-06 dt 4.47E-08 write d3plot file       09/19/23 15:44:53
   206 t 4.5568E-06 dt 4.54E-08 write d3plot file       09/19/23 15:44:55
   209 t 4.6991E-06 dt 4.69E-08 write d3plot file       09/19/23 15:44:58
   211 t 4.7946E-06 dt 4.44E-08 write d3plot file       09/19/23 15:45:00
   213 t 4.8792E-06 dt 4.17E-08 write d3plot file       09/19/23 15:45:01
   215 t 4.9669E-06 dt 4.79E-08 write d3plot file       09/19/23 15:45:04
   217 t 5.0629E-06 dt 4.76E-08 write d3plot file       09/19/23 15:45:06
   220 t 5.1926E-06 dt 4.49E-08 write d3plot file       09/19/23 15:45:09
   222 t 5.2864E-06 dt 4.41E-08 write d3plot file       09/19/23 15:45:11
   224 t 5.3770E-06 dt 4.62E-08 write d3plot file       09/19/23 15:45:13
   226 t 5.4674E-06 dt 4.83E-08 write d3plot file       09/19/23 15:45:15
   228 t 5.5637E-06 dt 4.82E-08 write d3plot file       09/19/23 15:45:17
   230 t 5.6554E-06 dt 4.69E-08 write d3plot file       09/19/23 15:45:19
   233 t 5.7966E-06 dt 4.41E-08 write d3plot file       09/19/23 15:45:22
   235 t 5.8892E-06 dt 4.64E-08 write d3plot file       09/19/23 15:45:24
   237 t 5.9818E-06 dt 4.82E-08 write d3plot file       09/19/23 15:45:25
   239 t 6.0788E-06 dt 4.88E-08 write d3plot file       09/19/23 15:45:27
   241 t 6.1725E-06 dt 4.63E-08 write d3plot file       09/19/23 15:45:28
   243 t 6.2657E-06 dt 4.86E-08 write d3plot file       09/19/23 15:45:30
   245 t 6.3630E-06 dt 4.79E-08 write d3plot file       09/19/23 15:45:31
   247 t 6.4585E-06 dt 4.50E-08 write d3plot file       09/19/23 15:45:33
   250 t 6.5981E-06 dt 4.74E-08 write d3plot file       09/19/23 15:45:35
   252 t 6.6944E-06 dt 4.91E-08 write d3plot file       09/19/23 15:45:36
   254 t 6.7913E-06 dt 4.90E-08 write d3plot file       09/19/23 15:45:38
   256 t 6.8895E-06 dt 4.78E-08 write d3plot file       09/19/23 15:45:40
   258 t 6.9860E-06 dt 4.74E-08 write d3plot file       09/19/23 15:45:41
   260 t 7.0814E-06 dt 4.89E-08 write d3plot file       09/19/23 15:45:43
   262 t 7.1792E-06 dt 4.88E-08 write d3plot file       09/19/23 15:45:44
   264 t 7.2768E-06 dt 4.78E-08 write d3plot file       09/19/23 15:45:46
   266 t 7.3730E-06 dt 4.87E-08 write d3plot file       09/19/23 15:45:47
   268 t 7.4703E-06 dt 4.86E-08 write d3plot file       09/19/23 15:45:49
   270 t 7.5675E-06 dt 4.86E-08 write d3plot file       09/19/23 15:45:50
   272 t 7.6649E-06 dt 4.66E-08 write d3plot file       09/19/23 15:45:52
   274 t 7.7580E-06 dt 4.66E-08 write d3plot file       09/19/23 15:45:53
   277 t 7.8993E-06 dt 4.65E-08 write d3plot file       09/19/23 15:45:56
   279 t 7.9947E-06 dt 4.85E-08 write d3plot file       09/19/23 15:45:57
   281 t 8.0890E-06 dt 4.70E-08 write d3plot file       09/19/23 15:45:59
   time = 8.1844E-06, ncycle = 282
   283 t 8.1844E-06 dt 4.86E-08 write d3plot file       09/19/23 15:46:01
   time = 8.2330E-06, ncycle = 283
   285 t 8.2819E-06 dt 4.88E-08 write d3plot file       09/19/23 15:46:02
   287 t 8.3787E-06 dt 4.88E-08 write d3plot file       09/19/23 15:46:04
   289 t 8.4710E-06 dt 4.78E-08 write d3plot file       09/19/23 15:46:05
   291 t 8.5661E-06 dt 4.87E-08 write d3plot file       09/19/23 15:46:07
   293 t 8.6636E-06 dt 4.89E-08 write d3plot file       09/19/23 15:46:08
   295 t 8.7594E-06 dt 4.79E-08 write d3plot file       09/19/23 15:46:10
   297 t 8.8559E-06 dt 4.85E-08 write d3plot file       09/19/23 15:46:11
   299 t 8.9530E-06 dt 4.84E-08 write d3plot file       09/19/23 15:46:13
   302 t 9.0990E-06 dt 4.87E-08 write d3plot file       09/19/23 15:46:15
   304 t 9.1965E-06 dt 4.56E-08 write d3plot file       09/19/23 15:46:17
   306 t 9.2881E-06 dt 4.69E-08 write d3plot file       09/19/23 15:46:18
   308 t 9.3827E-06 dt 4.90E-08 write d3plot file       09/19/23 15:46:20
   310 t 9.4806E-06 dt 4.82E-08 write d3plot file       09/19/23 15:46:21
   312 t 9.5729E-06 dt 4.67E-08 write d3plot file       09/19/23 15:46:23
   314 t 9.6638E-06 dt 4.66E-08 write d3plot file       09/19/23 15:46:24
   316 t 9.7579E-06 dt 4.85E-08 write d3plot file       09/19/23 15:46:26
   time = 9.8512E-06, ncycle = 317
   319 t 9.8980E-06 dt 4.36E-08 write d3plot file       09/19/23 15:46:28
   321 t 9.9851E-06 dt 4.78E-08 write d3plot file       09/19/23 15:46:30
 *** termination time reached ***
   321 t 1.0033E-05 dt 4.78E-08 write d3dump01 file      09/19/23 15:46:30
   321 t 1.0033E-05 dt 4.78E-08 write d3plot file       09/19/23 15:46:30 N o r m a l   t e r m i n a t i o n              09/19/23 15:46:30
 Memory required to complete solution  :   2257K
 Additional dynamically allocated memory:   150M
                  Total:   152M T i m i n g  i n f o r m a t i o n
            CPU(seconds)  %CPU  Clock(seconds) %Clock
 Keyword Processing ... 1.0000E+00   0.41   4.9200E-01   0.20
  KW Reading ......... 1.0000E+00   0.41   3.3300E-01   0.14
  KW Writing ......... 0.0000E+00   0.00   3.1000E-02   0.01
 Initialization ....... 8.0000E+00   3.25   8.7360E+00   3.54
  Init Proc Phase 1 .. 7.0000E+00   2.85   7.0600E+00   2.86
  Init Proc Phase 2 .. 0.0000E+00   0.00   1.9000E-02   0.01
 Element processing ... 2.3200E+02  94.31   2.2922E+02  93.01
  SPH ................ 2.3200E+02  94.31   2.2922E+02  93.01
 Binary databases ..... 5.0000E+00   2.03   7.2970E+00   2.96
 ASCII database ....... 0.0000E+00   0.00   2.8000E-02   0.01
 Time step size ....... 0.0000E+00   0.00   1.5000E-02   0.01
 Others ............... 0.0000E+00   0.00   5.0000E-03   0.00
 Misc. 1 .............. 0.0000E+00   0.00   6.8000E-02   0.03
  Force to Accel ..... 0.0000E+00   0.00   6.6000E-02   0.03
 Misc. 2 .............. 0.0000E+00   0.00   3.7300E-01   0.15
 Misc. 3 .............. 0.0000E+00   0.00   1.7500E-01   0.07
 Misc. 4 .............. 0.0000E+00   0.00   4.3000E-02   0.02
  Timestep Init ...... 0.0000E+00   0.00   4.3000E-02   0.02
 T o t a l s       2.4600E+02  100.00   2.4645E+02  100.00 Problem time    =   1.0033E-05
 Problem cycle    =    321
 Total CPU time   =    246 seconds (  0 hours  4 minutes  6 seconds)
 CPU time per zone cycle  =    3016.115 nanoseconds
 Clock time per zone cycle=    3018.953 nanoseconds Number of CPU's   1
 NLQ used/max   136/  136
 Start time  09/19/2023 15:42:25 Â
 End time   09/19/2023 15:46:30 Â
 Elapsed time   245 seconds for   321 cycles using  1 SMP threadÂ
       (    0 hour  4 minutes  5 seconds) N o r m a l   t e r m i n a t i o n              09/19/23 15:46:30
September 21, 2023 at 2:26 pm
Loic Ivaldi
Ansys EmployeeHello, what kind of simulation you want to achieve ?
Check how the simulation behave. If you have this :
maybe you can see something wrong in the plot.
- Use the latest version.
- Check carefully material properties
- try lowering the timestep
- try with VP=0
Best Regards,Loïc
- The topic ‘About the d3plot files not fully generated’ is closed to new replies.
