October 8, 2024 at 2:21 am
JooJaehoon
Subscriberhello!I'm conducting structural analysis on stuff consist of several component in 2DA stress contour result has discontinuityI thougt this have violence on my physical intutionHow can I get continuous contour, or is it common behavior in physical perspective?I attatched stress contour.All component applied bonded contact conditionFixed support at left side and operating pressure applied at right sideThank you -
October 8, 2024 at 9:51 am
mohan.urs
Ansys EmployeeHey,
Localized high stresses are sometimes due to contacts which might have initial penetrations. Do check the initial contact conditions properly.
It can sometimes even occur due to over constrained models or poor support conditions, if possible share some model setup info if the initial contacts are properly setup.
The mesh also seems very coarse, with highly elongated elements. Can you share some mesh info too ?
Thanks
October 9, 2024 at 9:29 am
JooJaehoon
SubscriberHello mohan!thank you for applying.I applying operating pressure at left holes and clamping pressure at right side of top and bottomAnd, all component are connected with bonded condition.I attatched my analysis data(It is different case with I uploaded first.But, stress contour violence still remained.-
October 9, 2024 at 9:32 am
JooJaehoon
SubscriberI'm sorry but, I don't know how to attached my case file.
Can you know me how to do?
October 9, 2024 at 9:44 am
mohan.urs
Ansys EmployeeHey,
We (Ansys employees) can't download files even if you are able to upload it somehow. So i would suggest to use screenshots of the setup to convey your issue. Try to include mesh, boundary conditions, contact screenshots.
Thanks
October 10, 2024 at 12:52 am
October 10, 2024 at 12:53 am
5824
