About setting the number of cores (threads) in chemkin
    • yukiyuki
      Hi there.
      I would like to set the number of cores in Chemkin.
      Up to Chemkin2021R1, I was able to do this by changing the value of [Preference>Run/Output>Job Submission Preferences>Number of Threads].
      However, since Chemkin2021R2, the "Number of Threads" field is missing.
      What should I do?
    • RK
      You can go to Edit --> Preferences --> Run/Output
    • jcooper
      There is no need to make any adjustments. For 2021 R2, this setting was removed. Chemkin is not parallel like CFD, and it was found that setting the threads >1 resulted in little speedup.
      The main speedup advantage Chemkin has is for parametric runs, where Chemkin can perform the calculations for all parameter combinations simultaneously.
    • yukiyuki
      Thank you so much !
  • The topic ‘About setting the number of cores (threads) in chemkin’ is closed to new replies.
