About setting the initial conditions
    • labolatory
      I'm currently doing a thermo-fluid analysis. For example, how do I set if I want to have temperature fluctuations at only one point?nWith the standard initialization of fluent's initial setting, all cells are given the same temperature as initial conditions.n
      If you want a temperature to fluctuate you'll need a transient boundary or cell zone (source term or FIX) condition. n
    • labolatory
      Energy is defined in the cell zone (source term or FIX) condition.nWhat if I want to define the temperaturen
      At the start or during the run?n
    • labolatory
      start runn
      If it's just an initial condition use a Patch. Initialise with uniform values and then patch regions that are a different temperature. n
    • labolatory
      Thank you very much.nHow should I set up a Patch?nI don't know how to use it, so please let me know.n
      Look in the initialise section from the tree menu, once you initialise the model click on Patch and have a look around. You may need to create an adaption register to give yourself a region to use in the patch function. nIn Google look for fluent patch region and you'll see some YouTube videos.n
Viewing 7 reply threads
  • The topic ‘About setting the initial conditions’ is closed to new replies.
