April 24, 2022 at 5:36 am
Peter8415
SubscriberHello,I want to  calculate the radial force and tangential force of a PM pole of a PM Motor,now I can calculate the force(Fx,Fy) at the CARTESIAN coordinate system ,but I don't know how to change the force Fx and Fy to radial force and tangential force. How can I solve this issue?
May 5, 2022 at 4:07 amNKC
Your question is being answered in the below post.
Please restrain from creating duplicate posts.
about Radial electromagnetic force
Regards Navya
Viewing 1 reply thread- The topic ‘About Radial force and Tangential Force’ is closed to new replies.
Innovation SpaceTrending discussions- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
Top Contributors-
4107
1487
1318
1156
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
