December 11, 2024 at 7:40 am
JooJaehoon
SubscriberHello!ÂI'm conducting gasket compression simulation like attached picture.ÂI applied friction condition with coefficient 0.3 between components boundary.ÂAnd, y directional displacement applied at upper component to implement gasket compression.ÂAs a result, gasket deformation data but geometry overlap occured in white circle at attached picture.ÂHow can I fix it? -
December 11, 2024 at 8:51 am
ErKo
Ansys EmployeeHi
See our courses for some help perhaps:
https://innovationspace.ansys.com/courses/courses/contact-mechanics
https://www.youtube.com/watch?v=t5dVH40UvQU
Also perhaps you need some remeshing as it deforms and mesh is skewed.
Hope this helps
Erik
December 12, 2024 at 7:30 am
JooJaehoon
SubscriberHello Erik
I'll see you gave and operate analysis with remeshing.
Thank you for replying!
December 13, 2024 at 7:58 pm
peteroznewman
SubscriberIt looks like the contact definition only selected the flat top of the body and did not include the blends on the corners or the sides. Or if the blends were included, the Pinball Radius was too small and did not pick up all the nodes around the corner.
December 16, 2024 at 12:19 am
JooJaehoon
SubscriberHello peter!
I conducted simulation without blends
But, I solve problem by setting pinball radius option from your advise.
I got result without overlapping!
Thank you for applying!
6790
1332
1152
