September 15, 2023 at 5:10 am
ty_jpn
SubscriberDear everyone,
Maxwell cannot be used due to licensing issues.
I created the program below to simulate the effect of fringe electric fields on parallel plate capacitors in MAPDL, but the simulation does not work well./CLEAR/PREP7! プレートの寸法(μm単位をmm単位に変換)width = 0.1height = 0.02thickness = 0.003separation = 0.01! 3D 8ノード要素の静電解析用に設定ET,1,SOLID122! 無限要素を定義ET,2,111,2,1! 材料特性(真空の相対誘電率)MP,PERX,1,8.854e-12! 最初のプレートを作成BLOCK,0,width,0,height,0,thickness! 二番目のプレートを作成BLOCK,0,width,0,height,separation,separation+thickness! メッシュ設定ESIZE,0.005 ! 要素サイズを設定! すべてのボリュームにメッシュを適用ALLSEL,ALLVMESH,ALL/SOLU! 静電解析を指定ANTYPE,STAT! 境界条件ALLSELCSYS,0! 最初のプレートの上面に0Vを適用ASEL,S,LOC,Z,thicknessNSLA,S,1D,ALL,VOLT,0! 二番目のプレートの下面に1Vを適用ALLSELASEL,S,LOC,Z,separationNSLA,S,1D,ALL,VOLT,1! 解を求めるSOLVEFINISH/POST1PLNSOL,VOLT ! ノード解(電圧)をプロット! 電場エネルギーを抽出して容量を計算/OUT, CAPACITANCE_CALCULATION, , TXT*GET, W, ENER, , STAT, ENEV = 1C = 2*W/(V**2)*STATUS, C/OUTPlease tell me what needs to be improved.thank you -
September 15, 2023 at 11:14 am
Ashish Khemka
Forum ModeratorTranslated:
Dear everyone, Maxwell cannot be used due to licensing issues. I created the program below to simulate the effect of fringe electric fields on parallel plate capacitors in MAPDL, but the simulation does not work well. /CLEAR /PREP7 ! Plate dimensions (convert from μm to mm) width = 0.1 height = 0.02 thickness = 0.003 separation = 0.01 ! Configured for electrostatic analysis of 3D 8-node elements ET,1,SOLID122 ! Define infinite element ET,2,111,2,1 ! Material properties (relative dielectric constant in vacuum) MP,PERX,1,8.854e-12 ! Create your first plate BLOCK,0,width,0,height,0,thickness !Create second plate BLOCK,0,width,0,height,separation,separation+thickness ! Mesh settings ESIZE,0.005 ! Set element size !Apply mesh to all volumes ALLSEL,ALL VMESH,ALL /SOLU ! Specify electrostatic analysis ANTYPE,STAT ! boundary condition ALLSEL CSYS,0 !Apply 0V to the top of the first plate ASEL,S,LOC,Z,thickness NSLA,S,1 D,ALL,VOLT,0 !Apply 1V to the bottom of the second plate ALLSEL ASEL,S,LOC,Z,separation NSLA,S,1 D,ALL,VOLT,1 ! Find the solution SOLVE FINISH /POST1 PLNSOL,VOLT ! Plot node solution (voltage) ! Calculate capacity by extracting electric field energy /OUT, CAPACITANCE_CALCULATION, , TXT *GET, W, ENER, , STAT, ENE V = 1 C = 2*W/(V**2) *STATUS, C /OUT Please tell me what needs to be improved. thank you -
September 15, 2023 at 5:45 pm
wrbulat
Ansys EmployeePlease try the listing below. In electrostatic analyses, one models/meshes the domain enclosing the electrodes (not the electrodes themselves). The electrodes are usually represented by voids in a mesh of the domain that encloses them. I didn't bother to add the INFIN111 elements (it's a little tedious - pardon me for getting cheap on you). You can increase the value of parameter d_dmn in successive runs until the value of the calculated capacitance stops changing significantly.
If memory serves, INFIN111 will not account for additional electrostatic energy of the infinite domain that extends beyond the boundaries of the SOLID122/123 mesh. So if you do use them, my second approach for assessing the capacitance would be, I believe, the more accurate way (divide the charge reaction on one of the electrodes by the applied voltage difference).
Cheers,
Bill
fini/cle/vie,1,1,1,1/sys,del file*.png/PREP7C*** Plate dimensions (we'll assume this is in meters)eps0=8.854e-12 ! FREE SPACE PERMITTIVITYwidth = 0.1height = 0.02thickness = 0.003separation = 0.002 !0.010d_dmn = 0.010 ! DEPTH SURROUNDING DOMAIN EXTENDS BEYOND ELECTRODESd_inf = 0.005 ! DEPTH OF INFINITE BOUNDARY ELEMENT MESHesz = 0.003 ! MESH SIZEV = 1 ! APPLIED VOLTAGEC*** Configured for electrostatic analysis of 3D 8-node elementsET,1,SOLID123C*** Define infinite elementET,2,111,2,1C*** Material properties (relative dielectric constant in vacuum)!MP,PERX,1,8.854e-12 ! THIS IS ABSOLUTE PERMITTIVITY IN MKS, WHICH WORKS OK, BUT...MP,PERX,1,1 ! WE GENERALLY USE RELATIVE PERMITTIVITY INSTEADC*** Create your first plateBLOCK,0,width,0,height,0,-thicknesscm,electrode1_a,areaC*** Create second plateasel,noneBLOCK,0,width,0,height,separation,separation+thicknesscm,electrode2_a,areaC*** SURROUNDING DOMAINallscm,scrap1_v,volu*get,xmin,kp,,mnloc,x*get,xmax,kp,,mxloc,x*get,ymin,kp,,mnloc,y*get,ymax,kp,,mxloc,y*get,zmin,kp,,mnloc,z*get,zmax,kp,,mxloc,zvsel,nonebloc,xmin-d_dmn,xmax+d_dmn,ymin-d_dmn,ymax+d_dmn,zmin-d_dmn,zmax+d_dmncm,scrap2_v,voluallsvsbv,scrap2_v,scrap1_vC*** MESHesiz,eszvmes,allC*** ELECTRODE VOLTAGEda,electrode1_a,voltda,electrode2_a,volt,VfiniC*** SOLVE/soluallssavesolvfiniC*** POST PROCESS/post1set ! READ RESULTS INTO MADL DATABASEetab,w,sene ! BASED ON ENERGYssum*get,Wnet,ssum,,item,wC1 = 2*Wnet/(V**2)nsel,s,d,volt ! BASED ON CHARGE & VOLTAGEfsum*get,q,fsum,,item,chrgc2 = q/vC_nominal=eps0*(height*width)/separation ! NOMINAL FRINGE FREE VALUE/tla,-0.35,0.90,Capacitance (ANSYS, energy) = %C1% Fd ! ANNOTATION/tla,-0.35,0.85,Capacitance (ANSYS, Q/V) = %C2% Fd/tla,-0.35,0.80,Capacitance (nominal fringe-free) = %C_nominal% Fdalls ! CAPPED SECTION PLOTSwpro,,,90wpof,,,width/2/type,1,7/cpl,1plns,volt/sho,png $plns,volt $/sho,close $/wait,2plve,ef,,,,vect,,on/sho,png $plve,ef,,,,vect,,on $/sho,close $/wait,2/eof-
September 17, 2023 at 5:19 pm
ty_jpn
Subscriberdear Bill
Thank you for your answer.
I tried it right away and was able to successfully analyze it. It never occurred to me to mesh the area instead of the electrode.
I have an additional question: What kind of command operation should I use to extract the electric field leaking from the electrode?Where is the capacitance worth when there is a fringe?
Thanks
September 17, 2023 at 3:15 pm
ty_jpn
Subscribermisstake post
September 17, 2023 at 4:30 pm
ty_jpn
Subscriberpostscript
- The topic ‘About electrostatic field analysis in MAPDL’ is closed to new replies.
4803
1576
1386
1242
