June 23, 2020 at 4:43 pm
tingshen
SubscriberI´m trying to analyze the bending stress of the rectangular beam on Ansys workbench of modal analysis and response spectrum analysis, but, after the "solve", happens an error "a result is invalid with the current output control settings" in modal analysis.
June 25, 2020 at 12:23 am
peteroznewman
SubscriberDelete any result objects in the Solution branch. Create new results as needed.
Also, you may not have requested all output you want. Under Analysis Settings, there is an Output Request Controls section. Not everything is set to Yes to save on disk space. Change everything to Yes and Solve.
June 25, 2020 at 1:10 pm
June 25, 2020 at 1:22 pm
tingshen
SubscriberAnd I plan to attach my wbpj in the comment, but it mentioned: "File extension not allowed". Can I know how I should attach my wbpj in here?
June 28, 2020 at 2:56 pm
peteroznewman
Subscriber1) I wrote Output Requests, I meant Output Controls. You can see in your screenshot that there are some Outputs that are set to No.
2) You attach Archive .wbpz files here but ANSYS staff are not permitted to download attachments so you can get help from them by describing your problem in the post.
September 27, 2023 at 5:49 pm
Jeffrey Lailey
- The topic ‘a result is invalid with the current output control settings’ is closed to new replies.
