April 28, 2024 at 10:07 am
å¿»æ³ ç™½
SubscriberWhen I made modifications to a certain size variable in the microstrip line, the real and imaginary parts of the S21 model flipped (or moved half a cycle). When I converted the data to phase and amplitude, its amplitude was the same, but the phase difference was half a cycle. I don't understand the reason behind this. Experts who know the reason can help me analyze it. Thank you very much!
May 9, 2024 at 8:51 pm
Faezeh Tork Ladani
Ansys EmployeeHi there,Â
Are you using waveports? Make sure to fix an integration line so the phase reference is fixed the same in all instances of that parameters.Â
May 14, 2024 at 1:32 am
å¿»æ³ ç™½
SubscriberThat's indeed the reason, thank you very much for your answer.????
- The topic ‘A Question on Microstrip Line S21 in HFSS’ is closed to new replies.
