July 6, 2023 at 2:59 am
July 6, 2023 at 8:29 am
Forum ModeratorIf you check the mass flow on each channel are they the same? If you plot static pressure on the same plane I suspect it'll help you understand.Â
July 6, 2023 at 12:34 pm
stao li
SubscriberThe value of velocity and other parameters should relatived to the position. i checked the mass flow and static pressure , and they are the same. it confused me
July 6, 2023 at 1:21 pm
Forum ModeratorWhy would velocity vary with position? With a manifold & porous resistance in each channel why are you not expecting the above?Â
- The topic ‘a question about porous’ is closed to new replies.
1885
1404
1303
