A Problem In Overset Grid’s Post Processing
    • shangjialin
      Overset  mesh has two different zone, but the vorticity contour is not continue over edge of zone. Are there some methods for overset  grid's post processing to get continue vorticity contour? There are two pictures to show that vorticity contour is not continue. One vorticity contour is in fluent, the other is in tecplot.
      There may be some slight distortion as you pass from overset to back ground mesh. Please can you also plot for orphans etc (cell type) as it's very easy to have holes in the solution if you've not got that bit right.
  • The topic ‘A Problem In Overset Grid’s Post Processing’ is closed to new replies.
