TAGGED: deflection, displacement, modeling-setup-advice
August 25, 2023 at 7:33 pm
Cezary Ciesielski
SubscriberHello,
I am in the process of modeling a wheel moving on a rail surface. I want to analyze the deflection of the rail under a wheel moving at different speeds.
I tried to do it in explicit dynamics and in transient structural but the results didn't look right.The model consists of a beam placed on the ground (bonded contact) and a wheel placed on the beam (frictionless contact). The material of the wheel has a selected density so that, together with gravity, it acts on the beam with a force of 112.5 kN. The whole is fixed on the bottom plane of the ground.In the results, I care about the amount of displacement of the beam under the moving wheel depending on the different speeds of this wheel.I have attached a photo of the model.Which solver to choose and what to pay attention to when entering settings. Please help.
Thank you.
August 29, 2023 at 7:06 am
Ashish Khemka
Forum ModeratorHi,
You can use a transient analysis. Define velocity along the direction of motion. That should be sufficient.
Ashish Khemka
- The topic ‘A model of a moving wheel on a rail’ is closed to new replies.
1565
1386
1242
