July 22, 2024 at 7:02 pm
ayun
SubscriberHello,
We have a client who needs to model a cavitation in the water. Unfortunately, I was not able to get a convergency with different settings and models.
The geometry is relative complex with rotating domain. The pressure drop through all system is large (more than 1000 psi). Additionally, it is required to model the compressible flow.
So, the question is simple. Is it possible to get a converged stable solution for such case?
Thank you,
Alex.
July 23, 2024 at 9:21 am
Forum ModeratorYes. However you may find the cavitation isn't stable and this may require a transient solution.Â
- The topic ‘a convergence/stability problem with a cavitation’ is closed to new replies.
1891
1419
