June 20, 2023 at 5:06 pm
Vedana Wu
SubscriberHello,
The transient case I want to solve has known velocity-inlet and pressure-outlet boundary, and I want to know how the outlet works.
Firstly, I set a velocity-inlet and a pressure-outlet and would like to use DEFINE_ADJUST Macro to modify boundary condition every 50 iterations due to the difference between the inlet static pressure computed and the ideal one. But when I struggle for a while, an error message comes, which goes 'Recieved signal SIGSEGV'. Â
I don't know how can I push this to the next step and hope you can give me some advice. Thanks a lot.
June 21, 2023 at 8:34 am
Essence
Ansys EmployeeHello,
This error can occur due to low memory. Please check your system memory requirements.
- The topic ‘A case with unknown pressure-outlet boundary’ is closed to new replies.
