October 2, 2023 at 6:46 pm
Noura Mansour
SubscriberI tried to get graph between force and displacement of two nonlinear spring ( barrel and hourglass)Â
And the graph of two are the sameÂ
Can i know what is the problem ?
October 3, 2023 at 7:09 am
ErKo
Ansys EmployeeÂ
Hi
The easiest check is that for one spring design just run 2 analyses with 2 different E - modulus (G shear mod.). If that does not work, then add your results , graphs, models, bc, loads etc. here so members can see that and try and help:
All the best
Erik
- The topic ‘Same results on different springs’ is closed to new replies.
1305
