TAGGED: compressible, compressible-flow-air, hsfld242
April 11, 2024 at 8:00 am
Sebastian Albarracin
SubscriberHello,
Im trying to simulate a compressible gas inside a cube (0,1*0,1*0,1 m³) with a top plate attached to a spring (C=1 N/m) and Im using the following APDL commands:
when i supress the D command and apply a 100 N force to the top plate the displacement is accurate to the stiffness of an air suspension, which is proportional to the reference pressure (500000 Pa):
but when i unsupress the D command and i apply a force of 101 N, the fluid is no longer modelled and my top plate is holded only by the spring:
is it possible to simulate a fluid with a given internal pressure + an external force? or there are some limitations to 242 elements?
how come i can use the D command but not the IC command to initate the internal pressure? (is this the reason why my model doesnt work?)
April 11, 2024 at 9:32 am
erik.kostson
Ansys EmployeeÂ
Hi
See the help manual for hsfld242 – hdsp which is basically internal pressure (D command) is explained,
 and so is IC (see IC command for more info – it often needs large deflections to ON to work in static analysis).
Also this post explains the use of hsfld242: https://simutechgroup.com/contained-fluid-in-mechanical-fea-model-working-with-hsfld242-elements/
Erik
- The topic ‘242 Elements – compressible fluid’ is closed to new replies.
