Ansys Learning Forum Forums Discuss Simulation 3D Design Trouble seeing effect of internal water flow, on surface temperature of aluminum component….. Re: Trouble seeing effect of internal water flow, on surface temperature of aluminum component…..
Brian Bueno
 ediaz4
That is as expected.  The Fluid analysis will only look at the behavior of the fluid.  Any other boundary conditions will affect the fluid, but you will not see any change in the surrounding solids. Â
