Ansys Learning Forum Forums Discuss Simulation 3D Design Topology Optimization – New Minimise Volume to stress target question Re: Topology Optimization – New Minimise Volume to stress target question
subashni.satish
Hello Tim Dukes
Can you set the upper limit on the legend to 50MPa and check where these higher stresses are developed? Usually, the high stresses are close to the Fixed support, and it could be under the protected depth.
