Ansys Learning Forum Forums Discuss Simulation 3D Design Thumbnail Views in Explorer for SpaceClaim Re: Thumbnail Views in Explorer for SpaceClaim
Charudatta Bandgar
Hello Ghost1246
The feature is not removed with the new release as far as I know, what could be happening in this situation is probably a result of the way Windows stores the value of the preview handler file. It can only store 1 value at a time, so usually it has the older version location stored. installing an update will no overwrite this. If the old version is then uninstalled, there will be not link to the thumbnail handler for the new installation. What I would suggest you is, if it is possible for you, uninstall the versions and install the latest SC version first.
Regards.
