Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › SpaceClaim 2021R2 installation failure › Re: SpaceClaim 2021R2 installation failure
Devendra Badgujar
Hello Lukas
Can you once make sure that the files are extracted from the zip folder correctly and the installation is done by running 'run as administrator' and they have the admin rights? Also make sure they have enough space in the drive where they are installing.Try clean reinstall.
Let me know if that works for you.
Thank you.
